Veritas - Innovation in Tools
Latex Paint as Green Wood Sealer?
Philip Morris
>Typically, I have used the green wood sealer (wax emulsion?) sold by Craft Supplies.
The wife recently nixed several gallons of interior latex wall paint (flat) because she did not like the color. I was wondering if I could use it to paint the ends of green wood to prevent checking.
Thanks,
Philip
Re: Latex Paint as Green Wood Sealer?
Frank J
>Yes I have done it on a number of logs when I was out of the wax mix.
I put severl thick coats on it worked ok. It was about 14 months ago and the logs are holding up well.
Brian Hahn in SW Wisconsin
>I've used it for sealing log ends. Several coats works about as well as wax emulsion.
Just a caution. The pigments in paints are mineral and they are abrasive. Coating a rough turning will lead to frequent gouge sharpening when you finish turn it.
Keith Newton
>I agree with the others, only I like latex primer better than the finish paint.
deer seem to eat it around here
Mike Schwing from Maryland
>I tried the latex paint trick a few years ago. Something ate it off of the logs I had sitting out at the edge of the woods. I assume it was deer, but something out there eats it.
Latex Paint is a Poor Sealer.....
Wally Dickerman in Arizona
>A regular wood sealer is much better...
Wally
JohnKJordan in East TN
>R. Bruce Hoadley, in his book "Understanding Wood" writes this about end sealing green wood:
Any relatively impervious material (such as paraffin, aluminum paint, or urethane varnish) in ample thickness will do nicely. End-coating can be applied to relatively wet surfaces by giving a primer coat of acrylic latex material first.
From that, I suspect two coats of latex paint would be perfect if the wood stays inside. I've been afraid to try using interior paints outdoors in the weather.
BTW, hardware stores sometimes have great deals on high quality mismixed paint. I buy exterior paint from a local Ace for my beehives for $3/gal.
Mixed results
Steven Kubien
>Latex paint should work really well for end sealing since it breathes and does allow moisture movement. I have had good luck with relatively straight grained blanks using 2 coats of latex but introduce any funky grain or crotch pieces and it's been 'Check-City'. FWIW, I store my blanks in my unheated garage/shop/studio/disaster-area.
Steve Kubien
Ajax, Ontario
HaveWoodWillTurn
>Phillip, I asked the folks at "AnchorSeal" the same question. Their response was that AnchorSeal is made to NOT breathe. You want to try to force moisture out the sides at the same rate (in a perfect world) as the end grain. Anchor completely seals the end grain which helps accomplish this. I've used both and now use only the AnchorSeal. BUT, remember, free info is worth what you pay for it. ;>}
Me too
Bill Howatt
>I have used both and consider Anchorseal to be the superior product for sealing blanks - noticeably less cracking.
Bill
Keith Newton
>I leave my logs out in the weather, so they probably never get as dry as those of you who keep your under cover. If it hasn't rained in a while, I may hose them down, or even set up a sprinkler. I would much rather turn the wood in a green state than after it has dried.
As for totally stopping the moisture loss. I don't feel that it needs to totally stop evaporation. It only needs to slow the evaporation to the point that it does not loose it faster at the end, than it will move through the wood to not have a big gradient between the end, than last few inches back in from there.
Since I use a white latex primer, if it were checking, the checks would be easy to see, and since none are apparent, I feel that is good enough. If the wood is going into a kiln, that may be another matter.
By the way, Not all woods are equal. I have a huge catalpa out on the parking lot. I had cut some blanks off of the butt end before the beginning of Summer, and didn't get around to re-coating it. It went the whole Summer bare, without the slightest check ever starting. I have gained some new respect for this overlooked wood. There are not many light colored woods with as many good properties as this wood.
I just wish it didn't make me want to sneeze.
Thanks
Philip Morris
>Everyone,
Thanks for sharing your experiences.
I have about a half gallon of the "good stuff" and was just informed of several large pecan trees that were pushed over. I plan to go cut them up Monday before they are burned. There is probably more wood than I have sealer and it will take a few days to mail order sealer. That's when I thought of the paint. Sounds as though it will at least be a good temporary sealer.
Thanks again,
Philip
Re: Mixed results
>Steven, the reason that latex paint isn't a good sealer is because it breathes. You want something that SEALS the wood, such as paraffin or Anchorseal. Once, because I didn't have any wood sealer or plastic bags on hand I used latex paint. I lost some very good wood.
Wally
Re: Thanks
>Philip,
I don't know where you life, but around here this time of the year logs can stay outside for quite some time without any signifcant degrade, especially if you keep them out of the sun with a tarp or something, plenty of time to order some sealer without paying store prices.
Anchor seal is so expensive by the gallon that you might consider buying a larger quantity directly from UC Coatings. I bought a 55gal drum last time for use with my sawmill and for turning blanks, but even with sharing it with the turning club that much is almost too much. I think I'll buy 5gal next time.
BTW, a UC Coatings sales person called me yesterday just to see "how things are going". I suspect they are trying to drum up some year end business.
Re: Thanks
Mike Nelson
>I use white glue at around ten dollars a gallon, works great.
