Thinking about making a Three point tool: Question
>I have a piece of 1/4" drill rod and was thinking of making a three point tool or point tool.
Is 1/4" a good size?
How long should the shaft be?
If I grind it on my eight inch grinder it will end up slightly hollow ground. Does that matter?
I am going to use a hex plumbing fitting for a feral and let that establish the angles for the facets. How critical is the "other" angle that establishes the "length" of the facets?
Re: Thinking about making a Three point tool: Question
I think 1/4 will work. The "cutting" edge will be a little short but I really don't think that will hurt.
Shaft length really doesn't matter much but you will be rotating the tool left and right for different cuts so make it long enough to clear the tool rest on the handle side. 3 or 4 inches plush the length you need to put in the handle.
If I grind it on my eight inch grinder it will end up slightly hollow ground. Does that matter? No. I sharpen the edge with diamond hones and this seems to work just fine. Mine is a 3/8" shaft so the hollow grind would be greater than yours and it works fine.
It's not really that critical but since your tool is 1/4" I would make these angles greater than 45 degrees to give you slighly longer cutting edge to work with.
Re: Thinking about making a Three point tool: Ques *LINK*
Gordon Seto
>Barry,
I use the �" dia. X 8" long HSS tool bits from ENCO. This size is perfect for rolling tiny decorative beads.
The length is not critical; I fit it with a short handle. The small tool is not intended to stick out very far from the tool rest.
It is easier to hone it on a diamond than matching the faces on the grinding wheel.
The angles are not critical either. The 3 faces have to meet in a point; but they don't have to be perfectly symmetrical. You will adjust the toolrest and the angle of the edge to the wood in use.
Doug Thompson near Cleveland
>I did make up some blanks for a 3 point tool but never sharpened them. The steel is 7 1/2 total lenght with a 2 inch shank. No time to do it... I know get off the internet LoL I only move from 12 noon to 4 am except tomorrow when the alarm is set for 7am... that's the middle of the night!
>You've received all the good answers to your questions. I'll just give you another idea to weigh.
(This mod was not my original idea.) I reversed an old 6x48 belt sander, and fixed it verticle, and made a tool rest with moveable V block for the handles. The 120 grit belt travels away from the cutting edge, which raises a good burr if I want it, or I can hone it away with the diamond stone.
I sharpen all my skews, hand chisels, Vee Point, and my 3-point tool on it. (I didn't want the hollow-ground bevels, not that they're bad... I just wanted a flat bevel.) For the 3-point, I just lay the facet against the belt, and turn it on, and rotate to the next facet, etc.. It's a lot easier for me to do that with my shaky hands. Works for me.
