Bowl Gouge Problem...
Randy G
>But this one isn't really in regards to the use of it. Last night I went to Sharpen my Gouge and noticed that the Metal Tool part no longer is attached to the handle. In fact, after noticing, I could easily turn and pull the tool out of the handle. Now I'm sure this is an easy fix, but I just have never seen how to attach it back in since I've never made my own tool handles either. Any help would be appreciated.
Re: Bowl Gouge Problem...
>You can glue it. Epoxy will work fine or you can use CA (cyanoAcrylate SP?) AKA Super Glue. If I were doing it I would pull the tool out, noting how far it went in and score the shaft that goes into the handle with some coarse sand paper. Just a few linear scratches to give the glue a little "tooth" to grip onto. Probably not necessary, but hey, what does it cost? If you use CA you can coat the hole with the glue and shoot some accelerant onto the shaft and then insert it quickly. If you do that, be ready to move and do not hesitate. It is possible for the glue to cook off much more quickly than you expect and grab the tool about half way in. DAMHIKT If you do not use accelerant, it will take a while for the glue to set, because of the sealed nature of the hole.
If you use epoxy, you might have to clamp the tool into the hole until it sets. You can get some piston/compressed air action going and the tool will pop right back out. They like to wait until you are not looking. DAMHIKT either. You come back and hour later and there is the tool, half in half out and the glue has set.
And one more thing to not ask me about. This is a good way to glue the tool to your hand. Be careful and use a minimal amount of glue. Other wise, it will run out and onto your hands and set instantaneously and you are stuck, literally.
Bill Howatt
>I'd just put some epoxy on the tool shaft where it goes into the handle and stick it back in and let it cure. Don't put a whole lot on since you don't need it and if it runs to the bottom of the hole you won't be able to push it all the way in. You might get away with CA if the fit between tool shaft and handle is fairly tight.
Bill
Epoxy
Ron McKinley
>You can eliminate hydraulic action of epoxy by drilling a small 1/16" hole from the outside of the handle to intersect with the hole near the bottom. As the glue squeezes out it will fill the small hole and if any does squeeze out just wipe it off with a paper towel.
I recommend 5 minute epoxy. As I have had CA dry and grab before I got the tool completely in the hole.......Ron
Forget the glue
Rick Allen
>The tool/handle connection is designed for the possibility of tool removal. Just put the tool back in the handle and tap the butt end of the handle on something firm like the ways of your lathe. That will drive the tool a little deeper into the handle providing a secure fit. Most wooden lathe tool handles are designed this way.
You can of course use glue but there is really no reason to do so. Think about the forces acting on the bowl gouge when you are turning wood. There is always some force pushing the tool into the handle.
One thing to be concerned with is the depth of the hole in the handle. The tool should not bottom out in the hole. If this happen the forces which would normally insure the tool is seated will act to enlarge the hole. If the tool is bottoming out you can drill the handle a little deeper. Drill the hole a little undersized so the tool can compress the wood fibers thus providing a secure fit. Under normal use the tool will consume less than 1/8" a year. But because you are now aware of the tool being loose you will likely tap the butt of you tool handles regularly and consume much more than 1/8" a year. An additional 1" of depth will provide enough "headroom" for many years of secure service.
Steven Antonucci
Good point...
steve antonucci
>and even further, be careful if you are using an open pored wood like ash or oak for the handle. I've had CA glue "weep" out through the pores and make a mess all over my hand (no, I didn't glue myself to the tool...)
Steven
Randy G
>Great, thanks for the ideas. I think I'm going to try the glue method as I use the shear cut method on occasion and I was afraid of the tool twisting on me. Thanks for the help again
