Question for Mike Stafford and other box makers?
>What are you using to finish your boxes. I have made about six and need to finish them. Are you buffing them?
And How does the finish affect the fit of the lid. I have some that are a bit snug and some a bit loose and some that are juusstt riigghhtt.
Re: Question for Mike Stafford and other box makers?
>Barry I use wax on the inside but on the outside I use lacquer. I put it on pretty thin and then buff with the Beal. You do have to be careful around the lip if you have a vacuum type fit but I usually don't have any problems. I've also used minwax wipe on poly. It goes on really thin.
John, do you mask off...
>the inside when you apply the lacquer? Are you spraying or wiping it Ont he lathe? How long do you wait before buffing. I have had some trouble with buffing the lacquer right off. Does the wax interfere with the lacquer?
Carole Valentine
>Barry, sometimes on the inside I use spray shellac applied with a cloth while the lathe is spinning, then Kiwi neutral shoe polish. I think I got this from Drozda, but not sure. I may do the same on the outside or I may use just an oil and buff. Depends on the box, the wood and my mood. :)
Ron in Drums PA
>I use waterlox and buff when it's dry
2-4 coats on the outside,
one thin coat on the inside, wipe on and quickly wipe off.
I've also used blonde shellac and like that too.
The finish doesn't give me a problem with the fit of the lid.
Re: John, do you mask off...
>No I don't mask off any areas. However also don't sand my tenons. I make one final pass as carefully and cleanly as I can with the skew or gouge and that's it. On the inside part I usually use one of my small screwdriver scrapers to cut the last few thousandths to make it fit properly.
On rare occasions (well sometimes not so rare) I have actually built up the tenon thickness using multiple layers of lacquer but that's really tricky to do because it wants to build up at the bottom corner of the tenon.
This is only on small boxes. Larger boxes I leave the lids loose enough that the customer can open them with one hand. I find they sell better.
Mike Stafford
Mike Stafford
>Hi Barry, I finish, wax and buff my boxes while still on the lathe.
I use a variety of finishes depending on the wood and what best brings it to life. I use thinned poly, shellac but not very frequently and wax. On occasion when I get a wild hair I will use a mixture of poly, oil and mineral spirits thinned a lot to serve as a friction polish. Seldom, if ever have I had finish interfere with the fit of the lid. If you apply enough coats you can get a loose fitting lid to fit a little better just as John said. I finish the inside and outside of the box with the same finish. In between coats I buff the finish with 3M non-abrasive pads.
Just like John, I don't sand the flange unless it is absolutely necessary. I hope to be able to cut it cleanly enough with my skew that it will not need sanding. If I do sand it I will only make a couple of swipes to loosen up the fit if that is necessary.
I almost always apply a coat of microcrystalline wax after the finish has cured to help eliminate fingerprints which can be a problem with boxes as people like to handle them. I generally buff the box with a shoe polishing flannel or a fine piece of felt like those you can get in hotels sometimes for touching up your shoes.
keith zimmerman, Normal, IL
>I like to use Waterlox on my boxes. I apply the finish on the lathe, then after it is all done I wipe on another coat to the outside. I don't usually buff my boxes because I really like the soft finish from the Waterlox.
keithz
Walnut Oil
Barbara Gill, Remlik VA
>Don't forget that walnut oil(drying kind)is good for the inside of boxes.
Re: Walnut Oil
Mike Jones
>Awhile back, I applied some Mahoney Walnut Oil to a piece of work and had about a 3 week wait (in the California sun) while it 'cured'. The surface never did get really dry until I overcoated it with Waterlox. I am still wondering about this...comments anybody ??
Re: Walnut Oil
>I don't have any trouble with my walnut oil but I only use it on the inside of boxes.
Re: Walnut Oil
jeff myroup
>I think it depends on ther type of wood and the oil content. What kind of wood was it?
Jeff
