Making a new tool, need help
TomCollins
>I picked up a Hunter #4 cutter and want to make the shaft to mount it on. I have a piece of 1/2" diameter steel that I need to mill a flat spot on where the Hunter cutter will mount. I have limited metal working skills but most of the usual tools including a drill press and grinder. The surface needs to be flat when completed so the cutter is well supported.
Is there some type of cutter or grinding wheel I could mount in my drill press that would allow me to make a nice flat surface on the steel rod? Is there another way to get a nice flat surface with my limited tools?
Any ideas, sources for cutters etc would be appreciated
Tom
Re: Making a new tool, need help
Dennis Yoder
>Tom I used a 3/8 mill in my drill press and used an x-y vice to feed the bar into mill. This allows to create a curved rear surface to hold the cutter firmly. Did you get the screw from Hunter to interface with the cutter firmly? The screw has a bevel behind the head to properly secure the cutter. You can get the screw and proper torx driver form Hunter tool.The torx screw is 4.0x0.70mm and the proper drill is 3.30mm. Have fun with your new tool, I have been having a ball. Dennis Y
Re:Try hacksaw and file. You'd be surprised.
Al Crandall
>A blacksmith in 1836 would have that job done in 5 minutes with the above mentioned tools. (Not tapping the hole, of course, but forming the flat.)
>Tom The cutter doesn't have to be recessed to work properly. It only needs to sit flat. I've made 3 tools. One of them I made using just a file to flatten the metal and get the angle. With care you can do that.
I do strongly suggest getting the torx screw that goes with the cutter. It has the proper taper to fit in the cutter. If you use a screw with the wrong taper you can crack the cutter.
I've done some milling with a drill press but it's very tricky. They simply aren't made for milling. It's also important to drill the hole dead center in the milled slot. You will also need a metric drill. They are easy to find at your local store that sells RC cars.
With a flat surface you can drill the hole as close to the area as you can. Then after you mount the cutter scribe a line on the shaft around the cutter. Remove the cutter and grind away the rest of the shaft up to the cutter. Then reinstall the cutter and your ready to go.
Steven Antonucci
A blacksmith today...
steve antonucci
>Would grind it the way I do... with a beltsander inverted in a vise.
I used the flat platten and an old belt. Takes about 20 seconds, but don't touch the metal, cause it gets crazy hot...DAMHIKT.
Steve
Mike Hunter
Mike Hunter
>Dennis and John ... you are correct, the use of the torx screw is critical. The tap specs are:
#1 cutter ... use a # 1 screw, M2.5-0.45 tap, T-7 torx wrench
#3 & #4 cutters ... both use # 4 screws, M4-0.7 tap, T-15 torx wrench
Please email any pictures of your tools. I read WoodCentral every night and look forward to your comments.
Mr. Hunter,
Eddie Pacheco, San Jose, Ca.
>The screws only clamp on the small ledge where the curved/radiused surface meets the shallow counterbore, right? That's how I modified the flathead screws I had so as to avoid cracking the insert.
Great invetion, by the way, and next time I'll be sure to order the screws with the insert.
Re: A blacksmith today...
TomCollins
>Steve, thanks for the tip. I never thought of using my belt/disk sander. I'll be sure to wear my welding gloves!
Ordered the screw and torx wrench from the Hunter site last night so I'm almost good-to-go.
TomC
Protect your eyes too...
Jorge Castaneda
My version
Mike Brazeau
>I had picked up a #3 Hunter cutter at Woodcraft in Rochester on the way back from Totally Turning. I quickly located the 3.3 mm drill and bought a good quality 4 mm tap but getting the Torx screws through Industrial Suppliers was impossible as they wanted to know the manufacturer of the cutter. A fellow guild member bailed me out with some from work. I saw Mike Hunter's tools at Woodcraft and wanted a little more beef on the shaft so, picked up some 1/2" CRS and opted to make it like the Eliminator that Packard sells. I mounted it in a Oneway handle that I have from my coring set. I plan to make a holder for my boring bar system as well when I can get to it. So far I have only fooled around with it, but it is simply AMAZING!
How I did it
Mike Brazeau
>I mounted the stock in my spigot jaws , turned at relatively low speed and with an angle grinder ground the taper on the stock. I fine tuned with the file. When close to what I wanted, I filed a flat and then with a 3/8 cylindrical stone in my Dremel tool, I then ground a recess for the cutter to fit in. When I had it sized where I wanted it, I marked the center with a fine marker, centre punched and then drilled while holding in a drill press vice clamped to the drill press table. I used the spigot jaws as a vice and with some WD40 for lubricant carefully tapped, bearing in mind the problems John Lucas had mentioned in tapping. I filed of the under side to round off and polished with the flap wheel on angle grinder, some coarse emery paper, and sandpaper from 220 to 1200 using WD40 as a lubricant.
Drilling setup
Mike Brazeau
>I made sure that he piece was parallel to the drill press table. I was a tiny bit off centre but not enough to matter. I find the magnify on a clamp incredibly useful, especially getting out slivers!
Close up
Mike Brazeau
>This was taken hand held with my Canon S3. Love that Image Stabilization!
Woodworkers Machine Tools
Mike Brazeau
>I couldn't believe how much fun I had doing this!
Re: My version
Ron in Drums PA
>Well Done Mike
Thanks
keith zimmerman, Normal, IL
>Tom, I recently made my own #4 Hunter tool and also used a 12" piece of 1/2" O1 rod. All I did was grind a flat on the rod, then pre-drill and tap the hole for the holding screw. After doing some profile grinding afterward, the tool works just fine.
I also made a #3 on 3/8" rod using the same process.
keithz
Thanks to all for your help. NM
TomCollins
Bit question
Ron in Drums PA
>Is there a reason for the bit to be completely supported from underneath?
Texian
>Thanks, Mike. Found your post.
Richard in Wimberley
