Both Sides Now 5257
Both Sides Now 5257
Both Sides Now 5257
Bruce Forrest
>This is another ash bowl. Both sides of this one have been fluted, bleached and sandblasted. I don't think it's quite "there" yet. Next one will have twice as many flutes both inside and out, lined up back to back. That will mean a bit thicker bowl overall. When I've got it "there", then I can get out the dyes, pigments and waxes. All comments welcome.
Re: Both Sides Now 5257
>bruce I like where these are going. Could you tilt the lip out a little. For some reason the straight across lip bothers me. I think if it tilted out a little it would show off the inside flutes better. That would also give it a wavy edge.
Donald Emmerling
>Hi,
I saw your earlier post before the inside had been done. Do you mind sharing with me exactly how do did the fluting? If you did it with a carving tool, can you tell me what brand it was?
Thanks
Don
Troy German
>Bruce,
Thanks for posting this evolving idea. It's fun to watch the process you go through for your creations. I look foward to your next post along this line.
If the flutes stay as wide as these, in might be interesting to make the inside flutes much wider. To me that would make it start to look like a seashell of some kind. Whether that's good or bad is up to you.
Thanks for posting,
Troy
Bruce Forrest
>Thanks. Actually, I think the problem is that the lip tilts inwards as it did in my previous posting where the inside wasn't fluted. Even just having it straight across would probably be better and solve the problem.
Another thought.
Bruce Forrest
>I'll probably keep it like this for a while for comparison purposes, but there's no reason that I can't remount it using the vacuum chuck on the bottom and experiment with making the lip straight across or even tilted outwards as you suggested.
Bruce
Robert Henderson
>How about 1-1/2 times the number of flutes?
While I agree that the flutes would look better narrower, I think half as wide would be too narrow.
Cyril Griesbach
>Well done, Bruce. I recall the last bowl with the smooth interior and commenting that without the contrast the fluting the inside may not work. I'm pleased to say I was wrong. I like this version just as well and they likely would go together as a pair.
Now I'll look forward to your continued pursuit of this concept.
Bruce Forrest
>I've sent you an email.
