Turning thin
Turning thin
Turning thin
eliot d
>I had occasion to turn a small open form very thin -- a little less than 1/16". Nothing special - just a small open goblet shape. I know enough to turn it to the desired thickness near the rim and then continue turning a thin portion in stages down to the bottom. But when it came to sanding the interior, I couldn't get it right. Too much vibration. Should I have sanded at each stage of the turning, the way I turned it, while there was still mass below the thin part?
Re: Turning thin
Re: Turning thin
JohnKJordan in East TN
>Don't know about your case, but when working very thin I usually have to support the outside with my left hand while cutting or sanding the inside with the right.
Same with spindle work. When making finger tops, for example, I turn the mass of the top first and sand and finish completely before turning the thin handle. I often have to support the finished part with my hand while working on the thin handle. Thin spindles such as hairsticks and wands almost always have to be supported.
Re: Turning thin
You are a brave man John
Ron in Drums PA
>I was going to say that, but I was afraid of the repercussions of telling someone to put their hands on a spinning object.
Re: Turning thin
Re: You are a brave man John
Don in Central Illinois
>I think we all know better, but I also, think that is the way to majority of us do it, anyway.
Re: Turning thin
>Thats the only way I learned to sand thin things. I'm told putting a rubber band around the outside will help but I've never tried it. I think putting your hand outside just opposite where your sanding on the inside usually works.
Re: Turning thin
Wally Dickerman in Arizona
>Sure, using your hand on the outside of a thin bowl is standard procedure. I do that when making the final passes on the inside with a bowl bouge, or when shear scraping on the inside. When turning thin bowls I do the sanding inside near the rim before proceeding further with final cuts. As the bowl gets thin it goes out of round to some extent, making doing any work around the rim difficult.
Wally
Re: Turning thin
>my favorite technique on goblets and boxes is to "trace" the outside with my fingers while the I'm shear scraping, and lately using the hunter tool, on the inside.
Re: Turning thin
eliot d
>O.K. you have confirmed what I thought: sand as you go -- not afterwards. (I believe the form is round; the problem is that it vibrates a lot when it's so thin.)
Re: Turning thin
Several years ago I mentioned the manual "steady rest" technique and was hit by one of the old guard for potentially endangering beginning turners. Turned out, no pun intended, this is a very common technique and quite safe if done with some common sense. Sure, stick your thumb down between the work and the tool rest and you'll wish you hadn't. Same thing for draping your arm and loose sleeve over a spinning chuck.
Regardless, if the biggest goal of WC was to preach absolute safety to 1st time turners and woodworkers, IMHO the advice should probably be stay away from power tools and take up scrapbooking instead.
Re: Turning thin
Tim GC
>Bravo, Well Said !!
Re: Turning thin
>I agree John. Working with power tools of any kind is a dangerous activity. You have to understand the dangers and know your limits. I use all the dangerous ones, the 4" chiansaw grinder, chainsaw, bandsaw and of course the Radial arm saw, plus many more. Guess what hurt me. a carving knife. I no longer have the use of the tip of my little finger due to a very deep cut from a stationary tool.
Re: Turning thin
No! scrapbooking
tek-Brunswick, Ohio
>You will get paper cuts!
I have seen some of the professional demonstrators show how to steady the work with your fingers. I can't imagine doing small delicate spindle turning without using the fingers for a steady. I also dampen the vibration with my fingers when turning thin bowls. I think the great majority of us do.
