cleaning pyrography tips
>I was doing a lot of delicate burning last night. The tip always burns much faster with cleaner lines if I clean the tip regularly. How do you all clean yours. I usually just keep a sheet of paper around and drag the tip across the paper occasionally. It's like starting with a freshly sharpened tool. Especially on this project because I was trying to follow some marks put on the wood by rubbing a photo copy with acetone to transfer part of the image to the wood.
Re: cleaning pyrography tips
Jennifer@Indy.USA
>John, I use a piece of stiff denim doused with rubbing alcohol to clean the tips if they get gunky, like when burning cherry. I lay it flat and use it like a strop. If it's just carbon build up a relatively soft brass bristly brush works great. Sometimes if I'm in a hurry, the inside seam of my jeans works good too. To sharpen I use a really worn out very fine diamond hone and leather strop. I don't use the hone very often though the strop is usually enough. I wore clear through a small skew tip once :( Guess what, then the circuit opens....no worky any more!
Jen
Art Liestman
>I hone fairly often (when the tip starts to feel "draggy") on a leather strop with green compound. On occasion, I'll flick the tip on a fine brass brush, but generally I just hone.
Andi Wolfe
>I keep a soft brass brush handy for cleaning off resin. Every couple of hours I'll hone on a diamond hone. I try not to wipe the tip on my jeans or on my dog (she's usually in my lap as I work).
Dick Hines
Dick Hines
>I am sure your dog thanks you.
>Jennifer Being male there isn't anyway I will wipe a hot iron on the inside of my jeans. :) I like the denim idea though. It's probably a little more abrasive than my paper and considerably less flamable.
>Art I had forgotten that some people strop their tips. I need a new strop for my sharpening anyway so I'll just move the old one to my burning kit.
Tim GC
>wiping on your jeans ... reminds me of .... gas welding on a bench tapping the rod through my fingers on the bench to get that 'balance'. Asked to tack a small job off the bench ... turned round made one small tack ... tapped the rod as normal Many Bad Words issued forth!!! Took the sick bay Doc 10 minutes to get the rod out of my thigh.
On, the heavy inseam John :)
Jennifer@Indy.USA
Dick Coers
>John, I suspect just the opposite. Brown paper is used by some as a buffing material on lathe work. Maybe something like 1200 grit?
