A ROBUST Moment
A ROBUST Moment
A ROBUST Moment
Ed Moore
>A cabinetmaker friend was commissioned to make some cylindrical pedestals for a metal artist. He has constructed this birch-staved piece with circular MDF inserts for me to turn. I never envisioned using the Robust for this sort of thing, but here we are.
A larger pedestal was made in two halves. It only needs the top insert turned to complete it. The top will be a piece of Baltic birch plywood with a 1/8th inch laminate of the same birch used for the staves.
Since the cabinetmaker needs a better lathe, I have encouraged him to get a Powermatic 4224 for future pedestals.
Ed
Re: A ROBUST Moment
Re: That's a damn big box Ed! But.....
JamieD
>... why didn't you recommend the Robust to your flatwork friend- price?
Re: A ROBUST Moment
Ed Moore
>Jamie,
The PM 4224 was the most lathe that I could talk him into. He watches his pennies. And to get the capacity he needs he would need a bed extension for a Robust.
He is a member of SMLW, but he doesn't really turn anything that I know of. He has brought me some interesting (read CHALLENGING) projects though.
Ed
Re: A ROBUST Moment
Mike Stafford
Re: A ROBUST Moment
Mike Stafford
>Since that staved box is mostly empty the Robust must not have had much trouble spinning it. I have seen pictures of pieces of logs nearly that size on the Robust.
However, all that said, the staved box idea does present some interesting opportunities. I hope you post pictures of the finished display stands.
Re: A ROBUST Moment
The Robust turns the staved ...
Ed Moore
>construction with ease. The MDF isn't strong enough though, so I had to put some CA glue where the drive spur was spinning in one of the small halves that I turned.
I glued a thin piece if oak dowel where the drive spur engages on this large pedestal. Hopefully the center will not spin in this one.
For future pedestals I will encourage the cabinetmaker to glue a small piece of 1/4" plywood at the center on the MDF sub-tops.
Ed
Re: A ROBUST Moment
The drum is turned and ...
Ed Moore
>all that remains is to turn a top and a recess for it. According to my level the side is straight and the ends are squared up. The end diameters are within 1/16" of each other. That should be close enough.
I did determine that 1/4" plywood is necessary to provide a secure place for a center spur.
Ed
