>So - I've been lusting after the LV turning tool roll ( maybe for Xmas?) - I've got my duffel bag though. I've been using the insulating foam for hot water pipes to protect the tool edges and sharp places while they knock around in the duffel bag.
What do ya'll use to corral the tools and protect the edges?
>A couple of inches of soft plastic tubing that will slide snugly over the end of the tool. Leave a little of the tubing past the sharp end of the tool. Works well..
>I protect the gouges with a piece of wood drilled to slip over the end. Everything else gets cardboard sheaths made from old cereal boxes. I carry them in a canvas tote bag or grocery bags.
My tool handles are too big to fit in an off-the-shelf tool holder, and it isn't worth the time or effort to make a custom tool holder.
>I bought a behind the seat tool box from Sears. It's long enough to handle most of my tools. I don't have it in front of me but it's about 8 or 9 inches wide, 2 1/2 to 3" deep and 22" inches long. Since they stack parallel to each other the only one I put a protector on is my skew.
>Her Majesty made me a tool roll. Wild colored, lightweight canvas duck, folded one end over 8", and sewed 8"long seams, 2" apart across that folded end, forming pockets. Hemmed it all around. Then I cut some 1 1/2" wide strips of vinyl about 15" long, and she doubled them over sewed up each side. These insert into the "pockets" to give some beef to them. The tools slide into the pockets, the other end of the cloth folds over them, I roll it up, and tie it with cotton clothesline rope. It works, and being so bright, it surely won't easily be misplaced... (grin)
I have a tendency to wing it - starting out with every intention of doing a Quick & Dirty and then as the project gets going things get out of hand. Still haven't put the case latches or a handle on this one.
By turning the lid upside down and slipping the
bottom box inside it, the tool handles are low enough to not interfere with using the lathe but high enough that I don't have to bend over to get any of the gouges or chisel. Does take a little organization to keep track of which handle is which tool.
My method
closest are
3/4" roughing gouge, 1/8" diamond/spear point parting tool and 3/4" curved skew
which I use the most, in that order
rest grouped "like with like" - spindle gouges, spindle master; other skews - 1/2" oval, 3/4" and 1" rectangular X-section then bowl gouges and special gouges and lamp augur that fits through the tail stock for "depth" control hole
Bottom of plastic pipes are open so stray chips and debris fall through.
