Way OT: For any telephone folks
Carole Valentine
>I am trying to figure out why my client's DSL service becomes unusable as soon as the sun goes down, stays that way all night, but is fine the next morning after the sun comes up! Nothing is turned off during the night, the router and modem are fine. This has been going on for two weeks tomorrow. He has spent a couple of hundred dollars on my service and untold hours on the phone with Verizon. Finally last night, I went over there and got on the phone with them. I won't go into details, but they really aggravated me. Finally, they agreed it must be something in the line and they would send a tech out Friday. Today, they called him and said the problem was fixed. At 5:00PM when the sun dropped below the trees, it was down again (connected but 50% or more lost packets which leads to constant timeouts). I am thinking that there is some sort of break in the line that expands when the sun hits it and closes the circuit but as soon as it cools down, it contracts and the break opens causing interference. Is this even remotely possible?
Re: Way OT: For any telephone folks
Ed Karch
>I would guess that you nailed it. Thermals are very difficult to trace. Fone folks would have to work it at night to catch it.
Carole Valentine
>Thanks, Ed. Is that what such a situation is called? A "thermal"?
Carole Valentine
>I think I am going to just tell them to change his pair and see if that fixes it. They could be trying to trace that forever. :(
Harvey Meyer in Atlanta
>I'm an old fone guy, but I'm a desk jockey nowadays. Could be many things causing this. The line could have a bridge tap left in somewhere between the house and the central office. Might work fine all day and then as soon as someone else comes home in the evening and uses a circuit that might be hanging onto that tap, then you go down. But VZ simple testing should reveal that and the fone would have some noise or static or hum. First obvious thing is to verify the fone is working when the DSL isn't. If the fone works at least you know you have continuity to the CO - if the fone has noise, hum or static, then you just proved it's the line. It could be caused by something miles away.
But other things that can cause this are -
something in the house that turns on right before it goes down and is inducing noise into the line - halogen lights are always a suspect. A bad DSL filter in the house that is picking up noise from a nearby appliance. The modem is too close to something that induces noise, or even something could be plugged into a fone jack without the dsl filter. Be observant, just when it goes down, try to notice what just turned on (or off).
And most of all, good luck - we're all counting on you.
Harvey
stacey s
>As phone guy now this sounds like a tough trouble to fix. I am suprised that after several visits that the technician hasn't already tried to change the pair, but Verizon may do things differently than Bellsouth/att does down here is south Georgia. One thing that came to mind that hasn't been mentioned would be to disconnect all other phone lines in the house, Including your alarm system if he has one. With everything disconnected I would connect the computer directly to the dsl modem and see if this makes a difference. It may or may not but if it does then it would indicated that something else you have connected in your house could be causing the problems. Hope this helps
Stacey
stacey s
>Changing the pair should be a quick and easy way to see if the other pair was bad. Your comment with the heat affecting the service is possible but will greatly depend on whether the cable feeding your client is in the air or buried. I would be less inclined to belive that this is the problem if all of the cable feeding him is buried. Another thing to possbilly consider would be what technologies are feeding him? Is he on fiber to the curb? or is he on copper? or possbily even fiber to the house? all of these would make a great differnce in what the problem is. I hope that you get somewhere with them. I think anymore that they higher at the lowest hourly wage possible and this make a difference in service.
stacey s
>Harvey are you still with the phone company?
Carole Valentine
>Thanks Harvey,
The the phone works. The DSL never really goes totally down, it's just not functional. To much packet loss. I told them that there was noise on the line and they finally agreed once I got to a level 3 tech. I asked my client about appliances or things that might come on when the sun sets (lights, etc.) and we couldn't find or think of a thing that had changed since before this started. This is a rural area with not many neighbors. Filter is installed at the interface which is inside the garage. I just checked the calendar and his problem started when we had the first decent rain (4") that we have had all summer. I am convinced it's in the line somewhere. I am going to make it a point to be there when the Verizon tech shows up tomorrow - the first one told my client he should use his modem and router as boat anchors and buy new ones from Verizon. I know for a fact that all the computers, the modem and the router are good.
stacey s
>You may have something there about the rain. If there is water in the line somewhere it can do funny things especially when heated and cooled by the sun going up and down.
Carole Valentine
>Thanks, Stacey. Feed is copper. Wires are underground except for the box by the street. Someone was sitting in their car this morning looking at it but never got out of their vehicle. Every computer in the house plus my laptop were affected the same. I have bypassed the wireless router and installed a "known" good modem. Same thing - same time of day - soon as the sun drops below the tree line. Weird.
>Sort of. I have over 38 yrs in "Bell". Used to work in NY Tel, then Nynex and then went to Bellcore. Still working for the company that is the "former" Bellcore doing software work for the telecoms.
You??
Ralph
>Carole
I'm not a telephone person, but I am an EE that got their training in Communications Theory from D K Weaver (and if you know that name, and what it means, you know he tried to teach me a few things).
I think you have had some excellent possibilities offered, allow me to offer one more.
RFI from a circuit that turns on at sunset and off at dawn. Possibly a lighting circuit, probably not an incandescent light, more likely a mercury vapor or (more likely) a CFL (compact florescent light).
I once had a similar problem (not with a DSL modem, but similar), turned out it was RFI from a CFL. In fact it was coming up the power-lines, on the neutral. I replaced the CFL with a regular incandescent and the problem went away. I later found a different brand of CFL that worked just fine.
Bingo!!!!! End of case. :)
Carole Valentine
>I just called my client back to tell him to be sure and tell the tech that this all started when we had the rain. I asked for the third time if he was SURE he had not done anything different around the house.
CLient: "No...oh - wait a minute...I put a photocell on the light outside the garage during that rainy period"
Me: Ok, go take it out and try your DSL
Client: You're kidding me??
Me: No I'm not. Come back and tell me if your Internet is OK (fiddle, fiddle)
Client: It's up!
Me: Go hook the photocell up again and go back and try the Internet. (fiddle, fiddle)
Client: It's down again.
Me: Go unhook it and put it in the trash. (fiddle,fiddle)
Client: It's fine. That's it! %$#@!&^%$! Why didn't you tell me to do that the first time???
Me: Because you didn't tell me until tonight that you had installed the photocell even though I asked THREE times about anything new that might come on at sunset. :))
Brian Simmons, Heflin, AL
>We had a similar problem only reversed. During the day the DSL would come and go but at night it was solid. Granted we are in a special situation as we are about 5.3 miles from the exchange and are using some specialized equipment. But anyhow, the phone tech changed the port we were on and all our connectivity issues went away. He did not know why, the tech-ier repeater guys did not know why, but hey it worked. Good luck.
Ralph, see my Bingo post above! :)
Carole Valentine
Re: Ralph, see my Bingo post above! :)
Ralph
>In my case the people didn't recall changing the light blub!
Dick Hines
Dick Hines
>Carole , is this guy on undergroung cable? The DSL could be working out of of an old lead cable. If so when the temps drop it could be causing the trouble. Years ago I used to get a lot of OT call outs to a government sight because they were fed with lead cable. When temps made a big change I would have to go in and reset a repeter. If it went from hot to cold or cold to hot.
Get Verizon to change his cable pair. But of course they will say they have no trouble on their end. You may have to get a vender meet.
Re: Bingo!!!!! End of case. :)
>And then there was the lady whose DSL only worked when she was in her basement office. When she went into another room, it didn't work. Maybe because the modem was plugged into an outlet controlled by a light switch that she turned off whenever she walked out of the basement office room.
Glad you got this one resolved. You done good.
Harvey
LOL! Error #1d10t
Carole Valentine
1 More Thing
>It's probably not caused by the photocell, but more likely caused by the light that it was turning on. It's probably a mercury vapor or halogen. Even if the light was already there and he just added the photo cell, it was probably always a problem if the light was turned on, but he may not have been using the light on a regular basis and probably didn't notice it, until the photcell started turning it on every day at dusk. A good test would be to put a plain old fashioned light bulb in there (if it fits) and see what happens. Or it could be the photocell:-)
Re: 1 More Thing
Carole Valentine
>I thought of that a few minutes ago. I am going to check on what the bulb is. I know it's not MV. I think it was incandescent, but I may be wrong - it could be halogen.
I am amazed.......
>I have been reading this thinking that It's like Latin or Calculus. I did not understand it. My thought was that "I bet there is one of those little solar panels you see on phone poles and when the sun goes down the power goes off." The idea that you could install a dawn to dust switch on your exterior light and knock out your Internet sort of ranks in there with the Alien Thought Helmets somebody posted the other day. I'm just glad there are people that understand this stuff. It's like the Bible to me, it's wonderful, but I don't understand any of it.
Re: I am amazed.......
Carole Valentine
>LOL Barry, I have learned that you can't rule out "anything" when you put a computer and a person (especially a technology impaired person) together. One of these days, I am going to compile a list. :)
