Piano Wire + Dragon Fly = Interesting? *LINK*
charlie belden
>Attached is another piece that involves two of my recent interests - multi-axis turning and piano wire to add actual movement to the finished piece. Also played with metalllic blue paint and gold leafing. I prefer the natural beauty of the wood, but when you're playing with a poplar dowel as your starting point, there isn't much in the wood to show off. Adding lacewood veneer wings is the show off the wood part of the piece. The base is turned from black walnut with areas "ebonized" with good old vinegar and rusty nails solution. Lots of tanin in walnut I guess cause it goes pretty black immediately.
The dragon fly body has a slight curve to it, done by turning a ball on the end of the blank and then chucking it up in a Nova2 chuck. Works sort of like the Escoulen ball chuck - not as precise - but free, assuming you already have a scroll chuck and can turn a ball on the end of a blank. (see included link).
The wings were kind of tricky. CN glued 0.015" diam. piano wire to the leading edge of each of the veneer wings. Not easy to do since the springy wire wants to be straight and the wing edge is curved, and not a simple constant curve. Nearly glued my fingers to a couple of the wings. Have since gone with copper wire of the same diameter. LOTS easier.
The wire on the wings is CN glued into small holes in the body of the dragon fly and provide a nice sail for adding movement. Since the dragon fly is attached to the landing stick by a piano wire slipped into a hole in the df's body, the dragon fly can rotate as well as move back and forth - sort of like it's hovering - about to land.
These things are fun to make and I suspect ladies would like them, especially if you did them in different colors - to match their decor. I suspect I'll be doing more of these sometime down the line now that I've got things figured out, more or less.
charlie belden
Method For Doing Dragon Fly Body
Re: Piano Wire + Dragon Fly = Interesting? *LINK*
Cyril Griesbach
>Very interesting, Charlie. What is the size?
Steven Antonucci
I like it and a suggestion
steve antonucci
>I think it's pretty cool, but I think the stick detracts from the overall effect. Perhaps you could turn a stick multi-axis that would be better suited to the theme. The stick looks kind of "unfinished" vs. the very finished looking dragonfly.
Love the dragonfly. Does it have eyes? I can't tell from the picture...
S
Re: I like it and a suggestion
charlie belden
>Re: size
the wing span is about 8"
eyes plus body a bit over 5"
pedestal base about 2" diameter
total height about 9"
The "stick" is a small branch of a grape vine.
We've got a LOT of grapevines in Nor Cal and
a dragon fly about to land on the end of
a branch is a fairly common sight. I also like
the contrast between the smooth symetric
base, the asymetric and rough "bark" and the
shiny dragon fly hovering above. Adds a bit
of natural to play off the metallic blue and
gold leaf. Personally I think a multi-axis
Escoulenesque "branch" would look out of place. That's just my preference of course.
When you make your version post a pic - I'd
like to see your idea.
If you have a scroll chuck the curved body
thing isn't real hard to do - IF you're decent
with a spindle gouge, skew or bedan.
Attached is a simpler, thinner dragon fly-
the body all on one axis so it could be
done between centers - no chuck required.
The gold leaf is available at most hobby and
crafts supplies stores - about $10 for 25
sheets, another $2.50 for the "sizing" you
paint on where you want the "leaf" to stick.
As for eyes - I cheated and used a back Sharpi pen. Have some small beading tools left over
from my jewelry making days. Basically these
things are small steel punches with a hemisperical convex in the end - with sharp sides. When you set a faceted stone in a prong setting you use these things to round off and smooth the end of the prongs. I'm thinking they might be used to stamp compound eyes elements - some are really tiny - maybe 0.1 mm. Could add some realism to
the next one.
charlie b
Steven Antonucci
Miner's Grapes?
steve antonucci
>I was in Jamestown and a guy referred to the vine as "miner's grapes". He said that they would plant them (concord grapes) so that they wouldn't have to stop panning for gold to eat (they could pick them as they stood in the streams- MRE!)
The vine on his property was 100' tall, and at least 12" thick- not bad for 150 years or so...
Steve
