Faceplates with a lip.
Brian Hahn in SW Wisconsin
>Last month I asked about faceplates with a lip. I couldn't find any, so I made my own. This 3" Oneway faceplate now has a 1/8" lip. The next picture shows how I made it.
Turning the faceplate lip
>I used a standard HSS 1/2" round nosed scraper. The lathe speed was about 300 rpm for the rough turning shown here. This speed is a little too fast for a smooth, clean cut, but it removes material fairly fast. I cleaned up the face at about 150 rpm, which cuts a lot cleaner but a lot slower.
Option B for making a lip.
>This is a generic 4" faceplate. This faceplate doesn't have as long of a hub as the Oneway - that's the nose of the spindle sitting flush with the surface of the faceplate. I epoxied a piece of mild steel (the body of a defunct sawblade clock) to the faceplate with JB Weld. I also pinned the steel in three spots with finishing nails. Then I turned it just like the Oneway faceplate.
Brian - I know you are going to tell us why??
The MountainMan
Advantage of the lip
>The biggest advantage of the lip is that the faceplate only touches at the outer edge, so the wood under the center of the faceplate can be uneven or domed and the faceplate won't rock on the piece. It makes for a very solid and trouble-free attachment.
Flat faceplates are fine for milled lumber, but don't work as well for rough cut or chain-sawn blanks. I found this out the hard way with my first lathe (a Sears mono-tube).
Re: Faceplates with a lip.
George Van
>Thanks Brian, I am going to modify my Oneway faceplate. I find your method eye-opening. I am going to check to see if a banjo/turret is available for my wood lathe so I could do simple ferrous and nonferrous turning. If it is it will probably cost more than purchasing the parts and tools I am hoping to make ;-)).
Ed in Leaside (Toronto, Ontario)
>I used to fabricate bits 'n pieces with scrapers, files, and the angle grinder. Then one day I was making a morse taper laser bed alignment tool from some 1" steel rod and came to the conclusion that my methodology was really dumb ... no make that totally inane. So I picked up a cross-slide ($115 CDN), and later the clamp kit ($60 CDN). Carbide tool bits are only a couple of bucks each, and I made the tool holder from a trailer hitch (dumpster find).
Here I'm making the swivel for my vacuum chuck.
