Thompson skew
Thompson skew
Thompson skew
>I finally had time to sharpen the thompson skew that I got. I was interested to see if it would get sharp enough to use as a skew. In the back of my mind I thought powdered metal might be like carbide and not get really sharp. Well I think I proved that wrong. I sharpened it like I do my HSS tools using diamond hones followed by green compound on a leather strop.
I established the initial grind using a 100 grit white wheel. That was a little slow but the metal cuts very well. I ground it 40 degrees from bevel to bevel and the tip angle is 30 degrees.
As you can see by the photo it is quite sharp. Certainly sharp enough to be used as a skew. I won't be able to use it until later this week but I think it's going to be a great skew. The rounded bottom should roll really well and the thickness should really help it cut cleanly especially if you have to hang it over the rest. I'll let you know what I think After I turn some spindles.
Re: Thompson skew
Bald spots
Troy German
>Do all turners have a bald spot on their forearm from testing the sharpness of their skews?
Just wondering,
Troy
Re: Thompson skew
Re: Hairy bowl
Bill Hale / The Wood Spinner
>Boy that bowl has a lot of hair !
Bill
Re: Thompson skew
I must have used my forehead to check sharpness
Re: Thompson skew
Re: Why is there only...
Allen Neighbors
>one bevel on this tool? I thought a skew had bevel's on both sides.
I'm serious. Don't know if I could even use this one with only one bevel. I've had such a hard time learning to use my others.
Re: Thompson skew
Re: Bald spots
russ Fairfield
>No0 but we have determined the cause of "Woodturner Pattern Baldness" on our heads.
Re: Thompson skew
One bevel, that's called a Bedan
>Actually even the bedan has 2 bevels, it's just one is flat. It's fun to use. Watch Jean Escoulen and you will see a master with this tool.
Re: Thompson skew
When confused,...
Troy German
>put the skew down before scratching your head.
Troy
Re: Thompson skew
Steven Antonucci
My son says I have "Devil horns"
steve antonucci
>When they meet and I have the "Ernie from Sesame Street Haircut", I'll willingly shave the rest...
Steven
Re: Thompson skew
Re: Thompson skew
Fog Tanner
>I have had and been using several of the Thompson skews for several months now (about 8 months), several 3/8" round and a 1/2" and 3/4". I use a Tormek for sharpening mine, along with my M2 skews. I use the 1000 grit surface on all my skews, and hone on the leather wheel. I will normally alternate between the stone and the hone, going to the stone only every other time. The surface has no grooves and a polished appearence. The edge will slice, not tear, through paper with a clean surface. It it doesn't then it isn't sharp.
I don't have any M2 skews as sharp as what my Thompson skews are. They are sharpened on the same stone at the same time using the same jigs and settings. All at 40 degrees with a slight radius. And the Thmpsons still come out ahead. They appear to agree with the Tormek.
I have taken to using the little 3/8 round skew for finishing cuts. I can get shavings off it that are almost like dust. The edge also stays a lot longer reducing the times to the grinder. When doing spindle work before, I would have 4 skews laid out, with one being for finish cuts only. Now I just need two and don't go to the grinder as often.
Re: Thompson skew
I Never could explain the bald spot on my head
Doug Thompson near Cleveland
Re: Thompson skew
Re: One bevel, that's called a Bedan
wilbur
>Does this method of grinding a skew give a "handedness" to the tool? I've used a skew chisel before, but not with this type of grind. It seems that it might make, say, rolling a bead in one direction easier/harder than rolling in the opposite direction.
Re: Thompson skew
>Wilbur I haven't turned beads with the bedan in so long I can't really answer your question. I don't remember it being any easier but I'll go into the shop tonight and play and let you know.
Re: Thompson skew
Thanks -- that would be great!
wilbur
Re: Thompson skew
How many use a Bedan? Is it worth making?
Re: Thompson skew
Re: How many use a Bedan? Is it worth making?
Ron McKinley
>I use one but the sharpening method recommended by Sorby doesn't work very well--diamond file across the top....Ron
Re: Thompson skew
Re: How many use a Bedan? Is it worth making? *LINK*
charlie belden
>If you've got a 1/4", or 3/8" bench chisel handy, chuck up a 1/2" dowel - say in poplar
- try a single bevel. Easy to try different
bevel angle since there's not a lot of metal
to remove on a 1/4" bench chisel. Try it bevel
up and bevel down to see what works best for
you. Hell, you can use a 1/16th inch parting
tool to turn really small. And by starting with
small diameter stuff to begin with mistakes
of the learning curve won't be a big deal - no
Go Change Your Shorts type catches.
Look at this stuff and look at the tools I used
to do them.
Give it a try at a small scale with very low risk.
charlie b
Turning Small With A Bench Chisel
Re: Thompson skew
JohnKJordan in East TN
>I bought one after watching a demo at our turning club, but I never learned how to use it efficiently on detail spindle work. I do find it good for flat-bottomed boxes and for some coarser cuts like sizing tenons, used like a fat, sturdy parting tool.
MHO: it would take a bedan revolution to put it on every turner's must-have list.
