Moffit light magnetic base
Dennis Yoder
>I just received my Moffit light with a magnetic base. I have knocked it over 5-6 times within the first 2 hours of turning. The problem seems to be the lack of attraction of the base.Does anyone else have this problem? How did you solve the problem other than replaceing the base. Dennis Y
Re: Moffit light magnetic base
Re: Was Mr.Moffit strongly attracted ....
JamieD
>...to the ferrous metal surface on which he was perched, or was it some less attractive metal, like aluminum? ;-)))
Jennifer@Indy.USA
>That's odd? The magnet that came with mine is Super strong, however mine did not come with a detent type thing in the base to keep it from slipping when stuck to a vertical surface. I called Moffat and they sent one. Apparently Woodcraft doesn't request that little thingy in the ones they stock.
Jen
Norm Smith
>Dennis, I have the same problem. I have a Powermatic and the magnet keeps getting knocked off. I cant see how to solve the problem.
Norm
Dennis Yoder
>Norm, That is the lathe I'm having problem attaching the lamp onto. Dennis Y
Dennis Yoder
>Norm, I found the customer service # for Moffatt Products, 800-346-0761. They said that the magnets should have an 100# pull and that they will replace mine without problems. Dennis Y
robo hippy
>I used to keep 2 of them on my lathe (PM), one on the banjo, and the other on the headstock. I had more problems with the one on the banjo than with the one on the headstock. I think that is because the banjo isn't dead flat. I now have one of the Blue Max lights that are advertised in Woodturning Design. It is a floor lamp, and I like the full spectrum lighting better.
robo hippy
Norm Smith
>Thanks Dennis,
Norm
>I've had one with the magnets on my powermatic and my Nova Comet. I have to rock them sideways to get them off. I don't think I could knock them off accidentally. They really stick. I bought mine when Gary Sander first came out with them. Maybe they changed the magnets over the years.
Cyril Griesbach
>Dennis, I've got one on my PM and one on Carol's Jet Mini and they both stick just fine.
Ed Karch
>I hang mine overhead upside down on a dust filter box. It has never been knocked off.
Detent thingy?
Peter Teubel
>Are you saying you have a coupler on the base that does NOT allow the lamp to pivot when mounted vertically?
George Van
>Dennis, I have the same problem on my Oneway, Moffit sent a replacement magnet stressing the 100# pull spec but this magnet performs the same as the old one. if I reach to move the shaded head of the light it will pivot off the surface. I did in all fairness to Moffit notice the pull much better when placed on the bed of my jointer. A rare earth magnet is difficult to remove from the Oneway so the steel must be adequate.
Peter Teubel
>Peel off the cover on the bottom and you'll see the magnet is a ring not a solid disc. unless you have the ENTIRE base in contact with a SMOOTH flat steel surface, the holding force is reduced.
