More scorching questions
keith zimmerman, Normal, IL
>A couple more questions about scorching with a torch. How much scorching does one do to achieve adequate results for a piece to be considered scorched? What kind of surface should I look for as I do the scorching?
I know I should just do it and see, but information from others is always beneficial.
Thanks in advance.
keithz
Re: More scorching questions
Molly Winton
>Keith, to answer your questions, "How much scorching does one do to achieve adequate results for a piece to be considered scorched?" As much as you want for the look you are trying to achieve.
"What kind of surface should I look for as I do the scorching?" Black
Real helpful huh? The easy answer is "It depends". Seems trite, but it's all dependent upon what look you are going for. If you want a light discoloration, go easy. If you want to texture the surface on woods that have soft and hard growth rings, burn the crap out of it and then brush off the soot (extremely cool texture). Then there are a mirade of inbetweens. It just depends....
Give it a try, and have fun.
Thanks Molly, just what I was hoping for
keith zimmerman, Normal IL
Pascal Oudet
>I use oxy-acetylene blowtorch to scorch. in this case, it's more to burn. the high temperature makes it very efficient, and quick. you don't have to stay a long time at the same place to get a deep black.
here is a picture of an ash bowl. I scorch and sandblast several times, until I get the desired effect. you can get an old leather effect that I really like (it's finished with oil. the inside is gold leaf).
Pascal
