>When burning designs on my turned pieces that I have sealed, the pen tip gums up, and the vapors are yucky. So I want to seal and finish after the burning. Sanding over burned designs has a deleterious effect, and, I don't know a way to get a good finish that does not incorporate sanding between coats. How do Y'all finish over your pyrography?
>Hi Mike, yes you want to finish after you burn. The fumes and gooey build up of burning finish is not good. Don't ask me how I know this :)
What are you using to finish over your burnings? I've only used Danish Oil followed sometimes by Rockler wipe on poly. Just recently I used Deft spray lacquer and it worked fine. One thing that you want to do after you burn is to wipe the burned areas down with a soft paper towel and rubbing alcohol. Make sure you use the high percent alcohol. 91% not the 70%. The lower alcohol content will raise the grain and ruined your sanded finish. The alcohol will dissolve any resins created by the high heat on the wood and give a much crisper look to your burn. Some woods are more prone to resins like cherry. Hope this helps.
