Mun Ebony boxes
Ed Moore
>Simple beaded boxes. The largest box is 1 3/4" x 2 7/8". This wood is better to turn than the usual ebony. I got it from Pete Kekel and Big Monk. The finish is Shellawax.
Ed
Mun Ebony boxes
Ed Moore
Ed
I thought that was ...
Ed Moore
>too easy.
Ed
Re: I thought that was ...
Norm Smith
>Ed, That looks great. Beautiful wood also.
Norm
Jennifer@Indy.USA
>Ed, your boxes are always nice to look at. Functional little gems. What did you call this wood? Mun Ebony? I've never heard it called that? I've always thought it was Black and White Ebony? Did I learn something new today? If so....yay! :)
Jen
Black & White Ebony boxes, I erred.
Ed Moore
>I just heard from Pete Kekel, and apparently I did not identify the wood correctly. It is Black and White ebony. Then, I must have a piece of mun ebony somewhere that I have misplaced because I know that I bought a piece of it.
Google mun ebony and you will see some beautifully grained wood.
Mea Culpa,
Ed
Re: Black & White Ebony boxes, I erred.
Mike Stafford
>Good looking black and white ebony boxes, Ed. I have a stick of that I am contemplating how best to use. I also have some ebony mun.
I have turned both into pens but not boxes as of yet. I look forward to it now that I have seen your results. Good stuff, Ed!
Fortunately, the box is ....
Ed Moore
>better than my photography. I don't know how I can take a picture against a gray background and end up with a blue background in the photo using the automatic setting outdoors.
Maybe I should read the manual.
Ed
the background looks grey to me
JohnKJordan in East TN
>Ed,
Do you see a blue background on the image you posted? It looks grey to me. (My monitors are calibrated with a Spyder colorimetric system) I loaded your image file into Photoshop and checked with the color tools. By the numbers the background is about as grey as grey gets. (The largest deviation from grey is in the center, but that is slightly towards the red rather than blue.)
If you see blue, your monitor may need adjusting. An easy way to do this without expensive equipment is display a greyscale or grey image on the screen and compare it with a grey card held next to the monitor. A piece of grey matte board works, or better, a grey card from a photo store.
Attached is the image with the numerical RGB values at selected points.
(If the image you posted has already been color corrected to remove the blue you mentioned, then nevermind!)
Thanks, John, ...
Ed Moore
>I had used Picture Window Pro to correct the background. I had the items outside in a tent and a gray background paper.
My basic complaint with my picture in its present state is that I probably should have tried to sharpen the image. I usually use Unsharp Mask, but I never know if the results are sharper. ;^D
Ed
Re: Ed- did you have the tent.....
JamieD
>... in the shade, rather than direct sunlight? Shade is a UV rich light environment and will turn everything blue, and the AUTO color balance is often inaccurate for such critical use. Even though some cameras have a correction setting for shade they are most often less accurate than a custom white balance setting, and John's suggestion of using an 18% gray card for correction is a good one. Adobe Gamma program may be available in your control panel as well, and it helps CC a monitor without buying more calibration tools.
The tent was in the shade. Should ...
Ed Moore
>I have let the sunlight hit the side?
The camera is a Canon A620. It seems to have plenty of options, but I'm like one of the infinite number of monkeys on the infinite number of typewriters, and I am as likely to type out "King Lear" as I am to get the settings right.
Ed
Re: The Kodal Guide to all known .......
JamieD
>....photo knowledge says sunlight between the hours of 10AM and 2PM for best possible color rendering! ;-)))
