Re: Pine for wood turning
Fog Tanner
>I have made a number of segmented boxes with suctin fit lids from Blue Pine. I can genrally get 7 boxes to the log, as the logs are only 1 1/2" x 3 1/2" x 8'. But for $2.15 a log at Lowe's, I can't complain too much. You can also use Orange Pine, but I am off Home Despot these days. I had a lot of fun making them, and they turned fairly easily. I still have several glued up to finish around Christmas time.
In one of the AAW magaiznes several years ago, someone had a platter that was made from segmented boards. They looked like dimensional lumber, but I want to try one from some more Blue Pine. The glue up is pretty straight forward, with several variations available. You would need to joint and plane the logs first, but still would make a neat project. One nice thing is it will let you make a platter as large as you can swing for a couple of bucks in logs and a little glue. Also on my winter list of things to do.
You might also look around for a place that uses pine or fir in their millwork. I found a place that has short off cuts they put in a pile to be taken. They work out to be the right size for boxes and other segmented projects, and the price is most excellent. Pays to ask sometimes when you see a pile of lumber setting by the entrance. My first pine segmented box was made from wood I got from that pile. I guess that would make it FIP wood (Found In Pile)....
