Heretical - Turning - Possible?
>Though the actual turning is very dynamic, the
end result is typically static. You can exploit
the grain pattern of the wood, dye it, slice it
and/or dice it, pierce it, texture it - hell you
can paint flames on it - but it's still in fact
static. Some of Escoulen's pieces look like
just stopped moving - but they're static.
I want things to move AFTER the turning is
done. Have tried counter balanced ball and
sockets for a pendulum effect, turned pieces
with low primary stability but high secondary
stability (think Blow Up Punch Me Guy with
sand in the base - tipsy but always rights itself - or google Super Egg aks Hyper Ellips-
oid).
Lately I've been playing with piano wire - the
0.015" diameter stuff - every springy. With
the right use parts of a turned piece can have
actual movement initiated by just a little puff
of air. Attached is the latest application
"Nail On The Head" - the second in a Cliche
Series. Everything but the piano wire was
turned. Have a turned dragon fly hovering
over a grape twig mounted on a turned base.
Still working out the wings - which will also use
piano wire.
My question is
Is using piano wire heretical in the turning
world? Is it even possible to be a heretic
when it comes to turning - the Wild West
of Woodworking?
charlie belden
Re: Heretical - Turning - Possible?
All's fair in Love and turning :) nice piece
Re: Pure heresy...
Allen Neighbors
>I love it. Your thinking cap must fit well, Mr. B. :)
It's called "mixed media"...
keith zimmerman, Normal IL
>and is a very valid medium in the art world.
Good luck with your investigation/experimentation/playfulness. I look forward to seeing your dragonfly when you complete it.
keithz
Re: Heretical - Turning - Possible? *LINK*
Peter Hyde
>Charlie: I was meaning to send you a response after checking out your site a few weeks ago. In our local Guild we have a turner Peter Rand who is a kinetic art fan. He is using stepping motors and Stamp microcontrollers to produce some amazing moving turnings. Piano wire is certainly acceptable in kinetic art and I would suggest you do a Google on the subject to see how far this art form has evolved from "Heath Robinson" machines to NASA technology.
Here's a link to Peter Rand's earlier stuff using piano wire
Have Fun
Peter Rand
charlie belden
>Peter:
Thanks for the link to Peter Rand. Every time I think I've come up with an original idea I find that several other people came up with the same idea - ten or fifteen or 200 years earlier - and used it in ways I'd never have imagined.
Plenty of great ideas of his on that page for dynamic pieces.
Still trying to figure out where the stepper motors are located on any of the pieces pictured on the page the url points to. I can see how a small stepper motor would be perfect for quickly - or slowly - rotating a platform under unstabile pieces, either mounted on spring wire or pieces intentionally with low primary stability but good secondary stability (tipsy but won't fall over).
I've seen the "femispheres" before but didn't think of their rolling/wobbling characteristic. The idea of using magnets is worth exploring - particularly their ability to repel each other. A "floating" piece might make for some interesting effects.
I'm not sure if the Heath Robinson reference was about early digital computers or Rube Goldbergesque contraptions. Either way the AllTheWeb search turned up some interesting reading.
Turning certainly is a wide open part of woodworking - unconstrained by function - leaving plenty of territory to investigate.
Again, thanks for the link and ideas.
charlie belden
