sycamore finish ?
sycamore finish ?
sycamore finish ?
Mike Hamilton
>All,
I turned a small flat-bottomed dish from quartered sycamore. I was wondering about recommended finish protocols to bring out the fleck without getting too dark. My archive search found a mention of Tried and True Oil and that was all. Your thoughts?
Regards,
Mike Hamilton
Plainfield, IN
Re: sycamore finish ?
Michael Pilla
>Mike, I'm not qualified to make other suggestions since I've not tried anything else but I can show an example of Tried and True Danish Oil on sycamore if that helps. Both handles are from the same block of wood. The screwdriver was given 3 very light coats of T&T. The difference is not as dramatic in person but it does darken the wood slightly.
If you decide to use T&T read the directions as it is applied a little differently than other danish oils. Very, very light coats are called for. I use a squirt bottle and literally dampen a rag with 4 or 5 drops at a time.
good luck,
Michael
Keith Newton
>If you are looking to darken the wood a little, I think dyes are a good choice. If you want to go dark. Use the dye to get half way, then use a pigmented dye to finish up, but neither alone will look very natural alone for a dark finish. My 2�.
Re: Thanks Michael
Mike Hamilton
>I have a different brand of 'Danish Oil' on my shelf and that is what I was considering. Darkening is my main concern. The piece has some brown heart wood some white sap wood and a bit of blue stain. I may have to look for some T+T.
Nice handles.
Mike
Re: Thanks Michael
Michael Pilla
>Thanks Mike. I know that different Danish Oils have slightly different formulations. Most contain some varnish and oil mixed. The T&T is polymerized linseed oil with no varnish (you can read about it on their website). That being said, I doubt there is a dramatic difference in the finished product among the different brands of danish oil. I could be wrong though...
Michael
Peter Hyde
>Use a Lacquer, Nitrocellulose or WB work fine and retain the natural colour. Or a WB poly will do the same. Any oil based finish will add an orange cast to the wood
