Scorching Question
Scorching Question
Scorching Question
keith zimmerman, Normal IL
>I was wondering, what kind of torch is best for scorching wood? Would a butane micro-torch work? Or would I use a propane torch be better?
Thanks in advance.
keithz
Re: Scorching Question
Carole Valentine
>I use a micro-torch that I got from a kitchen shop. Works fine for me but I only do small pieces or only the rims of larger pieces. I like it because I can easily control it with one hand while regular torch gets cumbersome unless you have the hose thingy.
Andi Wolfe
>Propane torch for large pieces, butane microtorch for small pieces or limted areas.
Peter Hyde
>I agree with Carol and Andi. Also on large surfaces try a spray of water on the piece first just to dampen the surface as it seems to allow more control. I spray a sealer coat of WB flat lacquer on immediately after the surface cools, that way I don't spread black fingerprints all over the rest of the piece. DAMHIKT
Thanks for the feedback
keith zimmerman, Normal, IL
>I was thinking just what you all have written as answers to my question. I guess I best get some butane for my new micro-torch.
keithz
Re: Scorching Question --another question
eliot d
>I just turned a natural-edged cherry burl bowl and finished it with varnish. But now I find that I wish I had darkened the edge. I s there a way, even though it's been varnished, to burn, paint, stain, etc. it?
Ed Karch
>Try your wood burner. Depending what varnish and how much it might work. be prepaired for some smoke.
eliot d
>Thanks , Ed. I' m also worried that there will be a fuzzy boundary between where I've burned it and the rest of the piece. I am hoping for a distinct boundary. Is there some way to create a sharp boundary between the burned, black edge of the bowl and the rest of the piecel?
Mac
>Try a permanent magic marker and then lay another coat of finish over it.....
I've used permanent marker with success.
eliot d
>Thanks for the responses. I 'll try the magic marker first, If that doesn't look so good, I guess I'll bite the bullet and go for the torch. I have one of those chef's burners that they use for certain desserts.
