Bowl turning speed - - survey
Pete in Holland, MI
>Assume a chuck mounted bowl. OD is rough turned. Focusing on the inside. Wood is solid & now balanced. How fast do you guys turn on bowls:
8" dia ?
11" dia ?
15" dia ?
18" dia ?
Just curious....
Pete
Re: Bowl turning speed - - survey
Stuart Johnson
>My lathe doesn't have a RPM readout so I don't have any idea. I do think that with in reason I get a better cut the faster it is spinning.
keith zimmerman, Normal, IL
>I can only comment on the 8" bowl as I turn on a Jet mini VS. I turn an 8" bowl at 1200 rpm.
keithz
Rick Allen
>The rule of thumb is diameter times rpm should be below 9000. That works out to a rim speed of about 30 MPH
I usually work at a speed less than that. For your specific bowl sizes that would be:
8" - less than 1125 rpm
11" - less than 820 rpm
15" - less than 600 rpm
18" - less than 500 rpm
I have turned faster, especially if there are voids that I don't want the tool to fall into. I generally turn slower that those speeds.
Lan Brady
>What Rick said as well. +/-10%
It is "+10%" if I find Blugrass on the radio,
then "-10%" for anything else. lol
Lan
Peter Charles Fagg (UK)
>In my experience I have never noted what the speed is in RPM, all I think about is do I dare to stick the sharpened steel thing into the wood at whatever speed it is running?
I have no idea of the RPM on my Record, the belt stays in the middle pulley unless I am trying to turn something of large (over 18 inches) proportions OR the lathe tries to chase me round the shop, THEN I reduce the speed!
Regards, Peter.
Steven Antonucci
About 1400 down to about 800 as it gets bigger
steve antonucci
>From time to time, I'll jack the speed up on a bigger bowl and throw shavings to the back of the shop, but I turn for fun, so speed isn't always my first priority. Faster only equals a better cut if you don't have to stop the lathe to run to the hospital.
Steve
Re: About 1400 down to about 800 as it gets bigger
Bill Hale / The Wood Spinner
>As fast as I can and hold below viberation from rgh to rgh finish.
At finish just below scarey.
I will never forget one of Ruds last demos. He had a n rgh piece on the lathe, everyone came in and sat down and his helper helped him to the lathe. He spoke for a moment and then he turned on the lathe with the rgh out of round piece. All together the audience let out a very loud "OH and AHH " as the lathe had to be on at least 2000 rpm.
He started to turn !
Good turning and be safe
Bill in CG, AZ
robo hippy
>I have a PM 3520A model which doesn't have a rpm readout. I core everything, and when bowl turning, I stay on the low speed range. If the piece is balanced, I turn at 1500 which is the max speed in the low speed range, regardless of size. This can go up to 12 to 15 inch bowls. On 8 inch bowls, I can see going higher, but then I would spend a lot of time going from high to low, and back speed ranges. The Oregon coast myrtlewood turners turn at 4000rpm. Supposedly there is a unique elasticity to myrtle that makes it stable at these speeds. I can see taking a while to get used to that speed, but wood does turn with less effort at higher speeds.
robo hippy
Dick Hines
Dick Hines
>Most chucks tell you not to turn over 600 RPM of so. I usely run a bowl up to 3 times that or until the lathe start to shake then down a couple of RPMs.
Wally Dickerman in Arizona
>My chucks have never said a word to me.
I turn at speeds that are probably higher than most. When I'm giving classes at Woodcraft on Jet minis, I have beginning students turn 7 inch bowls at 1200 RPM. If I was turning the same bowl I would move the belt to 1800.
Wally
Doug Thompson near Cleveland
>I also have a 3520A and took the time when it was new to mark the dial at 400 and 800 RPM. When roughing a chainsawn blank I start at 150 rpm and slowly increase the speed and never go over 400 rpm until the bark is turned away. When the blank is running true and was checked very carefully for cracks the speed is increased to 800rpm's
This was a 15-16 inch hat blank oups...
eliot d
>Do they really turn this fast.? 4000 rpm sounds insane to me! I watched Jimmy Clewes turn one of his Asian boxes at about 3000 . It's mostly " air", and it scared everyone half to death. ( One guy got up and moved to the back of the room.)
Re: Bowl turning speed - - Results are in !
Pete in Holland
>Well....it appears part of being a good wood turner is a small to medium amount of insanity in your system :)
Speed definitely has an impact of cut quality. One person seemed to kinda hit the nail on the head. Turn fast enough to utilize your time wisely, but not so fast so you waste it in the hospital.
Guess it just depends how large your "family jewels" are.
Thanks for the input........and safe turning !
Pete
