Scary but dumb moment in the shop
Steven Kubien
>I never thought steel-toed boots were necessary in the shop for everyday stuff but today has me re-thinking. Mounted a 50+lb maple blank on my Nova 1624. I don't have an outboard tool rest. Instead of moving the lathe around so I could access the back side and swivel the headstock, why don't I swivel the head into the room and hit the reverse button until it gets sized down a bit? I forgot which way the threads on the faceplate run and there is no grub screw on this one to lock it down. Blank came loose pretty quick and headed for the floor about 2 feet away. If it had landed on my foot I would now be referred to as Peg-leg.
Be safe everybody and I'll keep trying.
Steve Kubien
Ajax, Ontario
Re: Scary but dumb moment in the shop
Steven Antonucci
A very inexpensive outboard rest *LINK*
steve antonucci
>Check out my website to see a cheap and simple outboard rest for the nova...
It's under Shopmade Tools... and it's on the top.
Steve
Stuff I've made
Brian Hahn in SW Wisconsin
>Reverse turning without a set screw is a very quick way to dismount the blank! I've seen other people roll the blank across the room and bounce it off the wall. So far, I've been careful/lucky.
Question...
Steven Kubien
>From the picture it looks like one end is welded to an elbow which goes into the banjo. Fair enough. Is the other end firmly attached to the support post/base or is it resting in a groove or what? Looks like something even I can cobble together. Now I just need to find a saw and other flat work tools. They're around here somewhere.....
Steve Kubien
Carole Valentine
>Steve, what chuck are you using? If you are using a Supernova with insert, you have the wrong insert. You should have the one with the threaded hole (L) to lock the thing down to the spindle for reverse turning. Some of the major vendors will tell you that Teknatool discontinued that insert but it's not true. You need it to turn in reverse, as you discovered. Contact Tim and he will exchange inserts for you.
Steven Antonucci
no tools required, Steve
steve antonucci
>No welding. I'm not that sophisticated. :-)
What you see is basic black pipe, straight from HD. The center stud that fits the banjo was a 4" piece, if memory serves me, into a T connector. I chucked the center stud in my lathe and ran a file against it until it fit the banjo, which took a few minutes, but worked. You could also turn it or used a belt sander with the lathe running very slowly, but you only need to take it down about 1/16".
Then there is a little 4" piece on the oneside, and a longer bar on the otherside (length is up to you!) I think I settled on 3'. They are merely screwed together. I might have used loctite, or CA, to make sure that they don't back out, but they're so cranked down tight, they're not going anywhere even if I forgot!
The bar was then filled with sand to keep it from "singing" and add mass. I turned oak plugs and pounded them in to keep from spilling. The outboard support was cobbled together from construction debris, so it isn't pretty, but it is very functional. It can be slid in and out closer to the workpiece, and moved/angled to never be hanging too far over the toolrest. Basically, its a deadman with a hole at the spindle height. Make the base bigger, and maybe add a shelf for sandbags (I put my left foot on it when I use it).
I turned a 23" oak bowl on it once with the headstock rotated to 45 degrees (or so..) I think the plumbing parts cost $12, and it probably went together in an hour.
I keep saying I'm going to redo it and make a pretty one, but I never get around to it... send me a pic of your if you decide so I get off my backside!
Steve
Re: Carole, can you clarify...
Allen Neighbors
>the insert? You said the one with the threaded hole... is that a hole for a set screw? If so, where on the insert is it, in one of the flats that you put the wrench on to tighten the insert?
TIA
paul Waddle
>Glad you weren't injured. I did have a pair of steel toe shoes and I still got the end of my big toe smashed when the tap I was using to cut threads into a large pc of steel broke. This happened about 40yrs ago,so don't take any chances. By the way,and I'm not being critical,what is a grub screw?? I take it that it is a set screw???pw
Yes and yes
Carole Valentine
>The hole is drilled in one of the wrench flats and is threaded for a set screw. Actually, I think if someone has the capability to do it, they would be better off drilling and tapping their own hole. All of the ones I have have the hole tapped too near the edge (towards the chuck) and do not line up correctly with the area on the spindle that the set screw is supposed to contact. If I could find someone to redrill them I would. :( WARNING! You can screw up the threads on your spindle really fast if you forget the set screw is in and try to unscrew your chuck!
No chuck
Steven Kubien
>Hi Carole,
I was using a faceplate and there is no set screw. I know the insert you are talking about (I think Lee Valley carries it) but it wouldn't have helped. See, the Nova 1624 only has one threaded end on the spindle. If you want to turn outboard you swivel the headstock. If I am not mistaken, on lathes with a double ended spindle the threads are cut on opposite directions (on end left hand, one end RH).
Thanks for the thoughts.
Steve Kubien
Set screw
Steven Kubien
>Ya, I guess it's correctly called a set screw. Funny, the only thing I could think when I wrote that was "grub".
Cheers,
Steve
Re: Thanks, Ma'am, you're a gem!
Allen Neighbors
Steven Kubien
>Hey Brian,
I think I would need more than the 214rpm's and 1-1/2hp of the motor to send this blank across the room. Nah, this one came off and went DOWN.
Cheers,
Steve Kubien
Re: Except Oneway...
Allen Neighbors
>My oneway has right handed threads on both ends of the spindle, and each end also has a set screw groove.
Steven Kubien
>Didn't know that about the Oneway. Learn something every day!
Steve
Re: No chuck
Carole Valentine
>I'm confused. Maybe I am so tired I just can't read what you are saying. LOL I have a NOVA DVR. Doesn't matter if I swivel the headstock or not, I still use a set screw when I reverse turn. One of my face plates has a hole for a set screw, but I don't where I got it.
Re: No chuck
Stuart Johnson
>Does the DVR spindle have a grove for the set screw? With my Nova 3K a set screw would lock against the threads. I would think in time that would mess them up.
Re: No chuck
Tim GC
>'Continuing the thread' ... Bore and tap for a set (grub) screw ... but watch out it's a scary place to 'screw up' and not cheap either!!
Nah not going to apologise for the puns. hehe
Re: No chuck
Carole Valentine
>The set screw is supposed to hit the spindle just past the last thread. If the hole was bored correctly in the insert, it would.
Grub screw is Kiwi speak
Jorge Castaneda
>for set screw
Re: Grub screw is Kiwi speak
Steven Kubien
>I may have picked it up from my Kiwi sister in law.
