>The tailstock on my Jet mini slipped slightly from day 1, requiring a solid "thump" with the heel of my hand to make it hold. It has gotten worse over time. Now, to hold it firmly, I have to give the lever a whack with a plastic hammer. I have read various places that this is not an uncommon problem. Is there a cure for this?
>The best solution is to replace the round washer with a rectangular block. There should be several sources for such a block. One source that comes to mind is in the link below. I don't know which if any would work for a Jet mini. If you do a little measuring on your lathe you can find out the answer. Also if it isn't listed you will have the information needed to get one made.
>Joe When I get home late tonight I'll look and see if I have the photos of the rectangular block I made. It can be done with hand tools. The problem with the round block is there simply isn't enough surface area to really lock the tailstock. A larger surface area is called for. I made my block as large as the tailstock and it didn't slip at all. I sold the lathe so hopefully I still have the photos.
>Another consideration : If only the manufacturers would use fine threads on the locking mechanisms instead of course threads, the locking procedure in most cases would be much easier.
>clamp block? Mine on my little Vicmarc VL100 is a round, washer-looking thing, too. Only it's a lot thicker than a washer.
My tailstock on Little Vic locks down rock solid... is that a fluke? Seriously. I don't know why mine locks down so tightly... maybe it has something to do with the machining of the bottom of the ways.???
>Joe....Fred Groves, 1002 Tanglewood Dr, Greenville, TX 75402 manufactures a rectangular replacement for the round stock piece. He makes it from a solid piece of steel with a milling machine. His phone number is 903-454-1599 and his email is: fred226@aol.com. If I remember right the cost is $10.00. I went to a machine shop to see about getting one milled for me and they wanted $75.00/hr. with a $75.00 minimum and no estimate as to how much time it would take them to make it. So the one from Fred is an excellent deal.
>I have a JET mini with this problem and have noted others on other sites saying the same thing though not many as of late.
There is a sweet spot for adjustimg the nut under the ways that improved the situation.
I had always meant to wmh tool group to complain about this as the lathe was warrented for 2 years(time expired 5 months ago).
Though I know there a many making a "cure" for this problem it would seem the problem is so commonplace that Jet should correct it rather than me having to buy something to make it perform as designed.
