Vega bowl lathe
Vega bowl lathe
Vega bowl lathe
steve p
>Anyone using a Vega bowl lathe? I am a new tuner and would like some input. Thanks
Re: Vega bowl lathe
Re: Vega bowl lathe
Don in Central Illinois
>I don't own one but I have turned on two of them. Actually, one of them that I have used is serial # 1. They are great. Don't plan on turning anything long but they are great for large bowls. At Indyfest, we got to see their latest 'table top' model. Look's like it will be a little smaller version but still beefy enough to handle failry large bowls.
Re: Vega bowl lathe
Re: Vega bowl lathe
Bill Grumbine (Kutztown PA)
>Steve, I've owned a Vega for a little over two years now, and it is a great lathe. It ain't exactly pretty, but it is solid, and will handle a lot of bowls or hollow forms. It will not do such a great job on spindles, but it was not meant to. What I mean by that is you will be limited in the length of spindle you can turn. You are limited by just about any lathe of course, but the Vega will not allow you to turn table legs and longer things like that.
I've also demonstrated for Vega at a couple of symposiums, one just recently in NC. Several WC members stood round to heckle me while I was there.
If you can come up with any specific questions you would like answered I will be glad to try.
Bill
Re: Vega bowl lathe
Dick Hines
Re: Vega bowl lathe
Dick Hines
>Boy can Bill use the Vega lathe. I watched him at the NC symposium and it did not take him long to be up to his knees in shavings.
Bill is a heavy cutter so if the Vega will hold up under his work out it will hold to anyone.
Re: Vega bowl lathe
Re: Vega bowl lathe
keith zimmerman, Normal, IL
>I have turned on both the 2600 and found it to be a very good lathe. As others have stated, it is for bowl turning and not spindle turning.
keithz
