A55 Smoothing Plane
Boiling cow/bull horns for powder flask?
Roger Dunn
Roger Dunn
>A neighbor asked me to turn the stopper end and the pouring end with a plug for a bull horn to use for black powder shooting. The horn at the 'stopper' large end is oval in cross section so I'd have to turn a tenon for the large end and then shape it to fit inside the horn. I thought about boiling the horn to soften it up and then insert a round tenon into it but am leery that when a boiled horn cools and tries to take it's old oval form it will split apart like a hunk of Madrone. Has anyone done this exercise and is boiling an option or do I need to just shape the tenon and give it back to him?
Re: Boiling cow/bull horns for powder flask?
Brian Simmons, Heflin, AL
>Bowl some water and hold the horn end in the water for a short time and it becomes pliable. It will retain the new shape when it cools. I made one this way about 5 years ago, I don't remember how long to hold it in the water but I do remember how easy it was to form and that it retained it's shape.
You'll be fine...
Nick Stagg
>boiling the horn and inserting the wooden plug. Stick Dressers, that's what they are called, have used this method for a long time. Cow horn, however, is one of the hardest to work and shape because of the hollow core. If you were going to bend it you would need to support the inside so it didn't kink, rather like bending copper tubing. Buffalo horn is solid and rams horn are to a point.
You won't need to boil it for very long and be sure to have the tenon ready in the chuck for sizing purposes and if it needs to be reduced, just put the horn back in the water.
Good luck, Nick
John Uteck
>I've done a few plugs for a co-worker who carves or scrimshaws the horns. This is what I've done......
I first made him a cone that he uses to size the large end of the horn. The cone was approx 2" diameter at the small end, and 3 to 4" diam. at the large end, and 7 to 8" long. I turned the cone between centers from some hardwood I had laying around, and parted it into 3 shorter sections. Be sure to include a screw, screw eye, through hole, etc., to grab onto to remove the cone from the horn. With the set of 3 shorter cone plugs, you have a good range of diameters to use to size/round various horns.
Soften the horn by boiling, drive the cone plug in place, and let the horn cool down and take the shape of the cone -- be careful with driving the plug in place though -- the horn could split (That's why I let my friend do this part.....). I also let him drill the spout end.
All I do at this point is turn the two plugs to fit his sized horn and pre-drilled spout.
If you are going to hollow out the large plug, be sure to leave enough wall thickness to allow him to tack it in place on the horn. Also find out what kind of strap he wants to use, and how he wants to attach it -- this will help you design the finials if needed to hold a strap.
I have an article somewhere for sizing the horns, with a few ideas on plug shapes, etc. If you want more details, please send me a private email and I'll see if I can help you out.
john-uteck(at)carolina.rr.com
Remove from cow first
tek-Brunswick, Ohio
Roger Dunn
Thanks everyone!
Roger Dunn
