CA glue question
CA glue question
CA glue question
Ed Moore
>Some people use thin CA glue as a finish. I am making seven Christmas ornament bells from catalpa, as per the request of the owner of the catalpa, and one of the bells split. I used CA glue to repair it and the porosity of the catalpa meant that I will have to apply CA glue to the entire surface.
What is it that people use as an applicator when applying CA glue as a finish? Is it a batting of some type? I know that if I use a piece of tee shirt that I have made a mistake and will have a hot piece of cloth in my hand - and probably stuck to it.
TIA,
Ed
Re: CA glue question
Bill Hale / The Wood Spinner
>If I am going to cover tomething small I use my finger. I also use Med. and not thin. Thin is to fast. Be sure you have some releasing agent handy to clean your finger when done.
If you do this be sure your finger is DRY DRY DRY.
Good turning and be safe
Bill in Casa Grande, AZ
tek-Brunswick, Ohio
>Stick your finger in a sandwich bag first. Then spread the glue with your finger. Even old plastic grocery bags work. The glue won't go through it unless you rub a hole in it. I wouldn't use a part of the bag with printing on it though . The Printing may end up in the finish.
eaglesc
>You can use compress foam like they usse in the building industry under the plates when they frame a wall.
Also plastic food storage bags.
I would put a coat of thin first as a sealer and then use medium
THANK YOU!!! Ed
Ed Moore
JohnKJordan in East TN
>A demonstrator at our club said he applied CA to turnings with small tuffs of fiber batting held with hemostats. He pointed out it was important to use man-made fibers rather than celluolose (such as cotton), since the glue will react quickly with the latter. The batting he uses is made for upholstery or bedding.
Ric Taylor
Ric Taylor
>Ed,
I have two methods. I either use one finger of a latex glove to cover my finger, or I fold up a small piece of wax paper from the kitchen, which does a good job of spreading the glue evenly.
Ric
I use polyester batting on a stick.
Brian Hahn in SW Wisconsin
Dennis in Southern Oregon
>Ed, I often use the back of a discarded velcro sanding disk. It does not seem to catalyze the CA like cotton does. Dennis
Bob Boettcher
>If you make any pens, save the tiny plastic bags the parts come it. They fit your finger really nice, and are fairly tough
RJB
eaglesc
>" He pointed out it was important to use man-made fibers rather than celluolose (such as cotton), since the glue will react quickly with the latter. "
That may work for him but I'll bet more pen crafters use paper towels to apply CA that hemostats.
It really must look rather cumbersome.
Can you post a link to this demonstrators work?
It actually looked quite elegant! He held a small tuff of fiber with hemostats (I think it is polyester batting, as Brian Hahn pointed out), saturated it with glue, then held it to the work while slowly rotating it on the lathe. The resultant finish was flawless. I've used this a few times, but I generally prefer shellac based friction polish (Mylands) for small spindle things. (Also, I used up my little supply of batting.)
This was with larger diameter objects than a pen (I think he was making a bottle stopper) but I can't imagine that making a difference.
The problem I've had in using paper towels was the exothermic reaction of the CA to the paper fibers. Not only did the glue set up quickly, but it got very hot. Sometimes the paper towel actually smoked. Once I used too much CA and glued my finger to the smoking hot piece of paper towel. I won't do that again with my fingers.
I used a sandwich ...
Ed Moore
>bag and was able to distribute the CA glue without becoming attached to it or getting any on my hands. Because I had used the glue for a repair, applying it as a finish totally masks the repair and the bell ornament was saved.
Catalpa is very porous and thin CA glue wicks like a son-of-a-gun when applied to it. Porous woods often find themselves attached to people because of this capillary action. YOU HAVE BEEN WARNED! [grin]
Thanks to those who offered suggestions.
Ed
