Re: Thanks all-Another question?
JohnKJordan in East TN
>>Anyone think there's a downside to having a
>rechargable set of NiCd batteries in a conventional
>flashlight? 4 D cells= 4 NiCd D's?
Voltage for a nicad cell is lower than alkaline: 1.25v vs 1.5v, so your bulb would only get 5 volts rather than 6. The light might be somewhat dimmer unless you replaced the bulb. On the plus side, with reduced voltage the bulb should last forever. You will also have to provide an appropriate charger.
Another thing with nicads - nickle based batteries (nicad and nimh) lose their charge at a pretty high rate compared to other batteries. They work best for high drain applications, used often. If your flashlight use is like some where the thing sits for months until you absolutely need it one day, alkaline batteries may be a better choice. But if you use it for some hours every day, nicads might make save you money in the long run.
BTW, my new favorite flashlight is a Magnum 4 cell with alkalines and the bulb replaced with a super bright LED. I haven't done a side-by-side comparison on battery life, but I've been using it several times a day for months now and the batteries are still strong.
