Have a question? Ask Woody!
spraying finishes
spraying finishes
spraying finishes
eliot d
>Perhaps once and for all I can learn what's the deal on spraying finishes on my turnings. I never do it( except maybe lacquer from a can.) I always just wipe on whatever, oil, shellac, varnish, wax, etc. while the lathe is spinning fast. I might put it on first with the lathe off, but then I like to work it in with the lathe running. I figure, "Why spray when you have a lathe that does most of the work?" Am I missing something?
Re: spraying finishes
Re: No, you are not missing...
Allen Neighbors
>anything. You're right as rain... it is easier to finish on the lathe.
I've been spraying lacquer for probably 28-30 years . Now that I turn wood, I spray very few pieces. Most are finished on the lathe. That hand-rubbed finish is hard to beat!!!
>I found that I liked a little higher build finish for my hand mirrors and now most other pieces. Not super glossy like Marks but just more thickness and protection than I got by using quick finishes on the lathe. Not that these were bad they just weren't what I needed for my hand mirrors. I spray several coats of thinned lacquer and get much thicker finish that a wipe on.
This is a speed question for my production work. I can get the same finish with multiple layers of wipe on finishes but it takes days instead of hours. I tried lots of finishes before settling on the furniture industry standard. The lacquer is a hard finish that is easily repairable if damaged.
I found that my ornaments sell better when glossy and it's quicker to put the right amount on with spray.
I don't have a spray booth and spray out my door. Obviously there are times when this isn't possible. I will revert to wipe on finishes on those occasions if necessary but I've found I can spray most of the year but sometimes have to wait a day or so when it's raining or rediculously cold.
jared
>A quick question, so what lacquer product do you use and what sort of spray gun do you use, if I may ask? Thanks Jared
I finish off the lathe except for Pens....
Jake Niedling
>I never finish on the lathe. I like to take them off and look at the piece and maybe do a little hand sanding if needed. Sometimes you see tiny sanding marks under different light and angles. I apply almost all of my finishes with a paper towel. That is either Watco oil or mixture of 50-50 deft lacquer & lacquer thinner. I put on 4 - 6 coats over the course of a week or so. Then buff out and wax. During this time I am turning something else.
Lacquer Choice
Rick Urban
>I'm not a lacquer expert with decades of experience, but I've been working with it pretty steadily now for about a year and have learned a lot from many mistakes.
I use both application methods, depending on what I want to do (like John was discussing).
Slop on, spin dry... as mentioned in the thread, it is important to get rid of the tool marks and sanding scratches ( I do 400-600+ grit). Then I slop on the lacquer. If there are very small flaws I would like to fill I will sometimes wet sand immediately with mineral oil to form a slurry that fills in. After that I do another slop on application. I use a paper towel to slop it on, but I use a small piece of cotton (t-shirt) material or a white Scotch-Brite to buff it, because I have trouble preventing the paper towel from putting lint in the finish. Caution: Never hold the rag in such a way that it could take your finger(s) for a spin!
Spray on... When I want a build up I can rub out (like a Mark Kauder wannabe) I spray. I'm not good enough with it to never get some orange peel but I'm getting better. I use Sherwin Williams Hi-Bild lacquer (comes in 5gals) and use a couple of cheap HF gravity feed spray. It dries fast and hard. I used to use Deft, but my impatience caused me a lot of problems working with an incompletely cured finish. I usually spray a mixture of 2:1 or 3:1 lacquer to thinner, and I try to put on as much as I can at one time without getting a run. I usually respray lots, because if the application is uneven or if I am careless I can easily cut through when I go through the rubout process. When done I use a gutted refrigerator with a 60-100W bulb with a thermostat as a curing cabinet.
My spraybooth is *really fancy* but it works like a charm... a bench transformed into a downdraft plenum, a cardboard box, a turntable, and a HF dust collector vented directly outdoors (don't know how to trap the VOCs). The separate air compressor is to reduce problems with humidity. When it is really bad I use a "reducer thinner" (some add a blush "reducer") which makes all the difference in the world. BTW the air conditioner doesn't draw outside air. One of these days I'll probably make a neater installation, but I'd rather turn wood.
Re: Lacquer Choice
>Rick Great write up. I use a brand of lacquer called Benco. It's made by a local company so I doubt you can find it. It's a commercial grade lacquer. I used to use Deft but had trouble buffing it. I had to wait 2 or 3 days before the Deft got hard enough. This stuff will get hard enough in half a day or so but i try to wait a day if possible.
I use one of the really cheap Harbour Freight touch up guns. About $13 most of the time. I've started keeping an extra handy because parts tend to break on them. The castings are really cheap. I get about a year or more out of each gun and sometimes you can swap parts from the brocken gun and keep going. I know I need a better one because it never leaves a perfect finish but leaves it close enough that I can buff out the marks most of the time. If the is noticeable orange peel I will sand lightly and spray another coat or I might just steel wool it slightly.
If I want a finish like Marks I have to spray really light coats and start sanding at 600 grit but it does work. It just takes me a lot longer than Mark.
eliot d
>So, what I'm learning, I think, is that using spray makes it possible to get a higher shine, like that of Mark Kauder. I saw Mark's work at one of the AAW Gallery shows, and , indeed it looked impressive. Is this the essence of the response? Can you get that look without spraying?
That's It!
Rick Urban
>That's the idea! In my limited experience I've not yet seen any lacquer finishes that surpass Mark's, and while there are variations in the process, they all involve a good buildup that can be sanded, buffed or micromeshed, and polished. The "slop on / spin dry" approach does a nice job for the time invested but hasn't a hope of coming close to the "spray on / rub out" method.
>Spray just builds a higher shine faster. For years when I wanted a glass like finish I would use Shellac or Birchwood Casey's True oil. I would brush on thin shellac and the True oil I rub on.
To get a glass like finish, the concept is simple, put enough finish on to completely fill the pores and then sand with finer and finer grits until you have a glass smooth surface.
Accomplishing this is a little harder and I think Russ said it best one time. There isn't any shortcut to getting a really great finish. It all takes time and elbow grease.
Rub on finishes are usually thinned so it takes a lot more coats to get a really thick finish. Brush on finishes build quickly but require more effort to smooth the layers. Spray on finishes build the quickest with the least effort to level. Of course they all require a learning curve.
