Jet Mini VS Modification
Martin Harris
Martin Harris
>I bought a jet 1014 VS in July and am having more fun than is legal(even in California) learning to turn.
My only concern is the power switch location. It is on the box that has to be opened in order to move the belt. I am always concerned that I will accidentally bump it on while moving the belt.
Does anyone know if it is feasible to move the switch the the same location as the non-vs model? Actually, anything is feasible I suppose, so the question really is "does any one know how to do it?"
Thanks
Re: Jet Mini VS Modification
Ed Larson
>Other options are to unplug the lathe when making a belt switch, install a switched outlet in the box that it is plugged into or make movable magnetic switch that you can plsce anywhere on the lathe. Just some thoughts.
Ed
>I've owned and worked on Jet minis for years. I've never hit the switch. It would be pretty easy to put a magnetic switch on. I think Woodworkers supply had one that looks just like the one on my Powermatic.
Martin Harris
Thanks for the advice
Martin Harris
keith zimmerman, Normal, IL
>I agree. I have had mine for 3 1/2 years and have never bumped the switch when wotking with the belt.
keithz
Pete in Holland, MI
>Standard practice for industry is to lock out the machine. It's your fingers in there. If the switch is close to where your fingers will be, simply unplug the machine. Better to take a few more seconds each time the belt is moved, than have to explain why you can't hold the turning chisels anymore.
When I'm into my machines changing cutters & such, the machines are always unplugged. Good piece of mind.
Your choice.
