is it warped?
JohnKJordan in East TN
>Barry,
It could be the chuck is binding from distortion caused by overtightening. There was a thread a few months ago discussing this.
I bought three additional chucks for my collection from a guy who evidently ate his Wheaties. (I like to have one chuck for each set of jaws to save time.) One was bound up like you mention - cleaning, lubricating, and working it didn't help a bit. It was so tight in places it was unusable.
I found by examination and careful measurement that the metal chuck body was distorted from the strongarming. One clue was the obvious out-of-flat condition of the top of the chuck body, as seen by reflected light, when the jaws were removed. Another clue was the pinion gear (internal in this one, on the key for yours) was badly worn from the abuse. Fortunately, that gear is softer steel than the circular rack gear inside the chuck so it was fine.
I repaired mine and today it works smoothly. I started by disassembling the chuck. I used a diamond sharpening stone to flatten the top, then carefully removed metal where needed on the chuck body with needle files and small diamond sharpening stones until I had the proper clearance and each piece slid easily.
