NOVA CHUCK PARTS
NOVA CHUCK PARTS
NOVA CHUCK PARTS
Alan Tolchinsky
>Hi All, I need some screws that hold the jaws in the chuck due to stipping of the heads. Besides the manufacturer, where can you buy these? Can you get them at local hardware stores? I think they're M6 x 10 mm screws. Thanks.
Re: NOVA CHUCK PARTS
Steven Antonucci
Got mine at Woodcraft
steve antonucci
>Never found them at Lowes or HD.
Steve
Allen Neighbors
>A real good hardware store should have them. They are not all that uncommon. Take one of your old ones with you to show the untrained clerk. :)
>I bought mine at Woodcraft, but I think Loses has an assortment of "unusual" screws and bolts in trays. Wonder what the chances of finding the right metric threads and the correct head style. I am guessing that you might want to buy a set so they would match and you could use the same tool on all of them. Also, try an auto parts store.
Dick Hines
Dick Hines
>If you can't find them clost to home callcontact Tim Geist at this number 304-295-8166. He is authorized Teknatool repair guy.
His e-mail address is tvgeistmfg@aol.com
Paul Zerjay
>I got mine at the local True Value Hardware.
JohnKJordan in East TN
>I bought a little kit from Woodcraft that had a set of screws, allen wrench, and some setscrews, if I remember correctly. I was afraid I'd drop a screw in the shavings one day and never see it again.
Juergen
>I've found them at Ace Hardware. Check out their metric single screw assortments
Don Evans
>Be very careful if you purchase these locally. Not all screws are created equally!
You may find the correct thread, but you also have to make sure the head diameter and the angle is the same on them as the one's originally from Nova (Teknatool).
If the angle and head is not the same then the screws will not set correctly and therefore may be prone to loosening during use.
I was able to find some local but noted the head was slightly larger diameter and therefore would not seat down in the hole correctly.
I ended up ordering another set (which comes with the little rubber pieces and the wrench) from Woodcraft.
Don
Alan Tolchinsky
>Thanks all for the info. I'm going to check out ACE etc. but I think I'll be ordering to make sure I get the right part. Appreciate the advise given here. Alan
Packardwoodworks
Jorge Castaneda
