outboard banjo
outboard banjo
outboard banjo
ryker acuna
>I have the Jet 1642 and I need to make an outboard attachment. I have a 19" bowl I turned on my friends lathe now I want to finish the bottom on mine. Does anyone have pics of a home made attachment to the end of the lathe. I welded a floor stand but my lathe is on carpet and the stand is to light and it wobbles alot. Im a pretty good welder and wanted to get some ideas about welded and bolt on attatchments. Thanks for all your help. Also would it be cheaper to buy and adapt something? Let me know. R
Re: outboard banjo
Re: outboard banjo
Gary in Zirconia,NC
>I'd look at the Vicmark for $300. Craft Supplies handles it.
Re: outboard banjo
Re: outboard banjo
Larry Bisbee
>Craft Supplies USA has Vicmarc Outboard Bracket in the 2007 catalog on page 34 (Item Number 191-8008 ) for $299.99 plus $35 shipping charge.
Re: outboard banjo
Re: outboard banjo
adrien
>Some years back I stuck a 3" steel pipe in a 5 Gallon bucket filled with cement. The upper end was threaded to take a reducing section into which the tool rest fitted. 'Twas a bit hairy, but I was able to turn a large piece outboard on a Myford lathe. Fortunately I no longer have the Myford 'cause I don't think I'd try it a second time.
At any rate a cement=filled base might help and not cost too much.
