Nova DVR question?
Nova DVR question?
Nova DVR question?
>I have a Nova DVR that is about five years old (2002 software). With the speed cranked up, it seems to take a while for it to stop. (I turn and look, turn and look, so I have been spending a lot of time waiting for it to stop.) I have never fiddled with the programing, but it would be nice if it would decelerate faster. Does anyone know if the programing can be changed to make it stop quicker?
Re: Nova DVR question?
Carole Valentine
>Barry, I doubt seriously if that can be programmed in through software alone, but I may be wrong. Patience, friend! LOL A little palm pressure on the handwheel is all I use when I am in that much of a hurry.
Bill Hale / The Wood Spinner
>Barry I don't know the nova system but on the Oneway I have a switch for braking. On heavy pieces it is off but on small it is on and decelerates quite fast.
Do you have one that may have been turned off ?
Good turning and be safe
Bill in Casa Grande, AZ.
Bill Howatt
>You not only need the programming but you also need a large braking resistor that gets switched into the circuit (it essentially puts an electrical load on the motor which is acting like a generator when the motor is coasting down). I may be wrong but I don't think the DVR has one but I certainly don't know for sure.
My big General doesn't have one and I just use the handwheel or knock the sharp corner off a rough turned bowl when it is slowing down :).
Bill
Ralph
>I'm not remembering any parameters that effect the slow down. I usually just reach over and grab the hand wheel and slow mine that way.
BTW, I learned a new GOTCHA yesterday. I was standing by the head and turning the outside of a bowl, as I did the cut it appeared to me that the speed was increasing....to realize is was!!! I was leaning on the speed control!!!!
Walter Ahlgrim
>The DVR does not do any electronic braking. I like it that way if I grab the hand wheel everything stops. I find it very frustrating to use an Oneway lathe I grab the hand wheel then the motor keep driving the lathe as it is programmed to slow to a stop on a glide path the motor will accelerate or decelerate to stay on its path.
You can program the DVR to accelerate at different rates. With heavy blanks I select soft start.
