Re-think the rationale......
Jesper, Denmark
>If your decision to used water reducible finishes in plase of the hydrocarbon solvent reduced finishes is your own long term health, maybe you should reconsider.
The main hazards with solvents in the "oil based" finishes are the flammability, odor and long term exposure. By long term exposure, I mean that your are working with the materials and use the finishes every day, not that the paint is in your haouse after painting.
These hazards are well know and can be dealt with by proper ventilation - AND WHEN THE PAINT IS FULLY CURED, THEY HAVE GONE. There is nothing but a film of paint resin left.
There is really no real "water based" finish other than stuff like whitewash. The water base paints should be called water reducible, as they can be thinned with water. The finished paint resin film is really not much different from the oil based paints, and there is a co-solvent in the mixture than allows the water to mix with the hydrocarbon paint resin. The VOC content is a little less than the oil base, but it is there.
Here is where you should be concenrned: The co-solvents used are things like Propylene Glycol Monomethyl Ether Acetate, PGMEA, which caused birth defects in women working with this in the semiconductor industry some years ago. This and many similar chemicals are in the water reducuble paints. They have rather high boiling points, and will therefore evaporate into your home over longer period of time. The long term effects of these are not so well known, so you should ask yourself:
"Do I deal with the short term known effects of hydrocarbon solvents in paint or do I prefer the unknowns of the water reducible stuff?" Please read the contents in the can. If there are things with long chemical names you do not understand, get the information you need from MSDS sheets or Google and then decide.
Here is the thing that really ticks me off: The use of the term "Waterbased". it is at best a misnomer and at worst a near criminal attempt at falsely labelling product to make the consumer think it 100% safe.
I'll get off the soapbox now......
