ADVERTISE HERE - FREE TRIAL
Tried my Hunter Tool
>I tried the No. 1 Hunter tool that came with my Jamerson captive system. I put the cutter on the handle of the Sorby Multi Tool hollowing handle and it worked great. The flat side of the handle seems to hold the cutter about where it should be. Now I need more practice. That thing cuts like crazy.
Thanks to everyone who pointed out you could use it freehand.
Re: Tried my Hunter Tool
Mike Stafford
Mike Stafford
>Barry, does the retrofit Hunter Tool for the Jamieson hollowing rig come slightly canted or is it a straight mount? I haven't seen one.
The reason I ask is that I wonder how the angle at which the cutter is mounted affects the cut and the learning curve to find the "sweet spot".
On all the swan neck Hunter Tools I have been trying out the cutter has a slight downward mount but no cant back toward the user.
I am glad you enjoyed using the tool. I love mine!
>The cutter is canted quite a bit. (30 degrees?) It's mounted on a 3/16" piece of square stock in a notch that is angled. The Sorby tool has a screw hole in it and I used the disk off the Jamerson tool on the flat side of the Sorby tool. (I think there is a similar disk for the Sorby tool, but I have been using the scraper on the the Sorby tool and did not take the time to look for the disk. The Sorby tool has a flat side and a round side. When using the 3/16" cutter, you use it flat side down and when using the scrapper you use it round side down so you can orient the scrapper any way you like. The flat side helps you keep the cutter registered at a consistent angle.
The Hunter tool's angle presents some interesting quandaries. If you pivot the disk, you seem to be changing the angle the cutter approaches the wood. It seems you would need a different setup/angle to clean up the bottom of the piece. The NO 1. cuts like crazy on the side, but does not do so well right across the bottom.
Someone here suggested running the lathe backwards and cleaning up the nib in the bottom. That showed a lot of promise. My problem this time was that I drilled a hole in the center to the depth I wanted but had a hard time getting rid of the last traces of the hole. Does one of the other Hunter tools do a better job sort of dead on to the bottom?
Thanks for the help, that little cutter seems to have more of a learning curve than it's size would suggest.
PS. Does Hunter have a web site????
>It occurs to me that I might be better off if I went to the master and saw how he intended for his tools to be used. All I have so far is the No. 1 cutter and that came from Lyle Jamerson. Why am I re-inventing how to do this?
Re: PS. Does Hunter have a web site???? *LINK*
>Cleaning up the bottom is the hardest part with the current Hunter tools. I'm going to try to modify one so the #3 tool extends out past the end of the tool holder. I think this might help. Mike sent me one to try that is on a 3/16 square shaft and it's tilted 10 degrees forward. I rotate this so the cutter is angled 50 degrees or so to the left and it seems to work well for cleaning up the bottom. Of course that would require that you use 2 tools.
With the #3 cutter and some care I can cut the very center out when hollowing boxes. You have to move the handle to the left so the very edge of the cutter is on the center of the center bump and you also need to cut with the exact center of the circular cutter.
By drilling to the proper depth with a 3/8" drill you eliminate the problem except for the last few cuts. This is where you slow down and do the above technique.
With the #1 cutter mounted in a straight bar or in the Jamieson rig rotate it so it's forward. Then you can use the same tecnique mentioned above.
The reverse cutting technique I mentioned before. You rotate the #3 cutter so it is angled from about 11 oclock to 5 oclock. Then cut from left to right. This is a little tricky requiring just the right angle and height of the cutter to keep from getting catches. Start really light and the catches won't hurt anything. Once you find the angle it will cut very cleanly to center. You will probably have to move the handle to the left more than you think. The outside of the cutter is angle down slightly. To rub the bevel you have to move the handle further to the right than it appears.
I posted Mikes Web site below.
http://www.hunterwoodturningtool.com/
Carole Valentine
>Barry, I have a #3 tool and have found it wonderful for cleaning up the nib. I don't find I need to put the lathe in reverse, though it would probably work even better that way. I simply cock the disk to almost vertical (maybe 10 degrees) and take very light cuts from right to left across the nib. I am free-handing...no captured rig.
Cleaning up the nib ...
Ed Moore
>with a Hunter tool is quite do-able. Assume that the tool is inserted straight towards the nib and the Torx screw is aimed at 9 o'clock. As Carole suggested, rotate the tool about 10 degrees clockwise and move the handle to the left. Take light cuts from right to left across the nib and it will be removed.
I think that people are trying to remove the nib by going straight in with the Hunter tools. That doesn't expose enough of the cutter. By moving the handle to the left 5 or 10 degrees with the tool aimed at 9:45, the cutter is exposed and it will cut the nib.
When you reverse the rotation of the lathe you accomplish nothing geometrically.
I have been making bell ornaments from catalpa (special request) and using the Hunters to clean up the inside of the bell. The wood is wet and not a first choice for turning, but the nibs have been easy to remove by the method mentioned.
Ed
Carol and Ed- Good Information
Barbara Gill, Remlik VA
>These are new tools and we are all learning new ways to cut with them. That's kind of fun.
Mike Stafford
Me too!!!
Mike Stafford
>The method that Carole describes is exactly how I do it. I found it much easier to clean up the nub and remove ripples from the bottom with the straight Hunter Tool. I had been doing all of that work with a swan neck Mike sent me to test and I was able to do so but when I got my straight #3 it was much easier.
Mike Hunter
Mike Hunter
>Thank you to everyone for their input. I take many notes and appreciate the support and creativity by all.
