Cole jaws screws stuck
Alan Tolchinsky
>Hi All, I had a problem with one of the screws that hold on my Cole jaws and had to buy a screw extraction kit to remove 1 screw. How do you avoid those screws getting stuck? This is a Super Nova chuck. Even when you screw them in lightly they get stuck. Thanks. Alan
Re: Cole jaws screws stuck
Stuart Johnson
>Alan, It sounds like there is a mix up and either metric screws or being used in standard holes or the other way around.
Allen Neighbors
>They will get stuck occasionally. The manual says to put a little lubricant on the underside of the screwhead when installing them, to keep them from getting stuck. Yeah, I know... I've never done that either, but I think I'm going to start doing so every few days, anyway. Mine seems to be a little hard to loosen sometimes.
Dick Coers
>Oneway used to have the flat head cap screws get stuck in the jaws until they started putting a copper based antisieze on them. I read somewhere that toothpaste makes a good antisieze. Never tried it because I have antisieze around for when I change spark plugs and work with aluminum in the garage.
Dick Hines
Dick Hines
>I bet the screws are stuck in my chucks. I have 5 with different jaws and they have not been unscrewed in years. I don't use the Cole jaws so I don't have the change the jaws to finish the bottom of my bowls. I use a piece of MDF board with cork glued to the face to keep things from slipping. I just bring the tail stock up and turn away.
Good luck with the screws.
Alan Tolchinsky
>Thanks all, I'll try some lube or antisieze.
Walter Ahlgrim
>That problem went away for me when I got a new set of screws and stopped using the L shaped wrenches. The off center forces from the L wrenches damage the screw heads. The T wrenches allow you to press the wrench into the socket while twisting, discard any screw that shows any damage. I have seen sparks fly when these screws break loose.
Anti-Seize
Tim GC
>I use 'Copperslip' a copper based compound found in tubes and small tins in most Autoparts stores. I use it on most threaded kit in my shed. Be warned though ... like any grease based goo, it attracts dust and shavings, a little bit goes a long way and it stains wood!! DAMHIKT
Re: Anti-Seize
Allen Neighbors
>That must be what I got with my lathe. There was a small clear plastic tube (the kind you cut the end off to open) filled with a coppery colored slick-em stuff to lube the banjo mechanism. I'd never seen it before, but I like it.
Thanks for telling me what it is! :)
