Can you bleach the color out of wood...
Steven Antonucci
steve antonucci
>imparted from an oil finish? I have a maple hollow form that's kind of yellow from the oil finish (I knew I should have used lacquer!), but I wondered if there was a way to remove the color from oil?
I'm guessing no...
Steve
Re: Can you bleach the color out of wood...
Steven Kubien
>Not sure if would work but try it on a test piece... How about mineral spirits? Might dilute the colour some. Might be a disaster. Definately use a test piece.
2 cents
Steve Kubien
>Steve I've been playing a little with bleaching the wood first and then putting the oil on. The idea is that the oil darkens the wood and makes it yellow. I hoped I could bleach it just light enough that after adding the oil it would look like it did before I bleached and added oil. It didn't work very well on cedar but did work on cherry and walnut to some degree. It does change the color on the wood as well as lighten so I haven't achieved the same look as a non finished piece.
some woods also don't bleach evenly. Box Elder for example bleaches the white but not the red or brown areas. Wenge bleaches the lighter brown but doesn't change the dark brown at all.
As always a test is necessary.
Steven Antonucci
Thanks(both)
steve antonucci
>I had bleached it beforehand to make it whiter, but the oil yellowed it so much, I'm probably just going to leave it alone. It doesn't look bad, but it doesn't look the way I wanted it to look either.
Steve
Re: You could strip it and put your lacquer on....
>If you really want it light, that's what I would do.
Steven Antonucci
It's too thin...
steve antonucci
>The price we pay for thin work is that oil soaks completely through...
Thanks
Steve
Heritic answer
tek-Brunswick, Ohio
>Next time use a water based lacquer. They change the color of the wood the least. I know water based finishes are not among the wood turners favorites. A sealer coat of blond or super blond shellac will pop the grain a little more, but will also add a little more color than just using a water based finish. The shellac does help keep the grain from raising. I just raise the grain with a light spray of water and sand it off if I want to skip the shellac. If your water has a lot of iron or minerals in it use distilled water. Iron plus wood with a high tannin content equals black stains. That and rust stains are why water finishes and steel wool don't go together.
