Questions for Mike Stafford and the rest of you...
>Are you using the Hunter tool free hand or in a captive rig?
I tried mine free hand and fond it a little scary.
How long does it take you make a box. I just make one out of Osage Orange and it took about 3 1/2 hours. First one I've made in two or three years.
Re: Questions for Mike Stafford and the rest of you...
Allen Neighbors
>I use mine freehand. I love it. I want a larger one. I started turning in '03, and for 2-1/2 years I turned with Oland tools, so it was easy for me to pick up the hunter and go for it.
I think it would be alright in a captured rig, also, but you'd have to get the cutter angled right and lock it in position. They used one of them in an elbow tool at the counter where they sold Hunter tools at SWAT.
I've only made about 9 boxes now, and I think it take me about that long to make one also. I hope to improve on my time as my proficiency increases.
Carole Valentine
>Free hand. I didn't find it scary at all. Which one do you have? I hear the tiny one can sometimes tend to self-feed. I use the #3
Mike Stafford
Mike Stafford
>Barry, I am using mine freehand and yes, initially they can be a little catchy until you find the right angle of attack. They do have a sweet spot. But once you find it they cut like crazy. Now I am speaking more of the swan neck tools. The straight tool cut very predictably with just a little practice.
>I believe mine is a #3. I got it from Lyle Jamerson with his captive rig. Tonight I just picked it up and tried it using the bar out of the hollowing rig for a handle. The cutter is less than a 1/4" in diameter.
I'll try it again.
Jennifer@Indy.USA
>Barry, it sounds like you have the #1 cutter there. I have the #3 and it's not that small.
Jen
>You have the #1 if it's about 1/4" in diameter. I believe that's what Lyle uses in his bar. The #1 in the 3/16 square bar has a 35 degree tilt which is about right for hollowing in a captured bar. At 35 degrees it is fairly aggressive and removes wood quickly.
When I use the tools in a hand held tool I rotate the tool so it's more like 45 to 60 when it's cutting. This seems to give the cleanest cut and doesn't grab.
keith zimmerman, Normal IL
>I have a #3 and a #4 and I like the #3 for boxes. It may just be me, but the two sizes seem to handle slightly different. I think I've figured out the #3, but I'm still trying to find it with the #4. I believe it is just a matter of time and practice.
keithz
Mike Stafford
About 2 hours....
Mike Stafford
>Sorry Barry, I failed to answer your question about how long it takes to turn a box. I can turn one fairly quickly but the sanding and finishing take almost as long. Once in a while I can turn a box in about an hour but it will be a very simple shape. I guess I am not a particularly speedy turner. I spend time with the lathe off looking at the box to see how I am progressing. I have also found that I need to let the wood cool down before fitting the lid. Sometimes the wood can heat up from turning or from sanding just enough to affect the fit of the lid so I find I have to let it assume room temperature before the final fitting. Otherwise the lid will be sloppy. Sometimes this happens because I remove too much wood...I haven't figured out how to put it back on.
I don't worry about how long it takes. I enjoy the process of each box I turn so there is no rush.
Cyril Griesbach
>While I thought I'd be in South Dakota when my #3 arrived it actually came in yesterday's mail. Got it right out in the shop after dinner and used it free hand on a hard maple project. I found it wanting to self feed at first but I think that's because I didn't have enough angle on it as John Lucas recomends. On this project, with and undercut rim, I found I needed to FREQUENTLY clear shavings with the air hose to keep a good cut. This prevents doing one continuous cut, at least for me. I'm still learning this tool, of course, but looking forward to it as well.
I did get some chatter hanging it over the tool rest more than two inches but I think it was because I was taking too deep a cut or the build up of uncleared shavings in the undercut rim.
I'm always watching for more info on using the Hunter from all the knowledgable users here.
Dennis Daudelin
>I have both the handheld Hunter tools (#3 and #4) and the Hunter tool in my Jamieson rig.
With the handhelds, it's important to find the "sweet spot" with the tool. To start hold the tool about 45 degrees to the left and then cut. I find that it works best to go from right to left with cuts and from back to front.
I got my Hunter tool for the Jamieson in a recent class with Lyle. He was clear that you can't go from front to back with the cutter or it will climb up on the work (self feed). He was also clear that you have to cut by pulling the tool from back to front. When I follow his instructions the tool works great. It is a small cutter but no smaller than the standard HSS cutter. Lyle's version of the Hunter tool is a square shaft and has the cutter angled to the left, just like you would do if you were holding a hand held tool.
Here is the exact text off of Lyle's site:
"Different than the scraper cutter, the cutting motion will be always to the left when cutting up under a high shoulder vessel make sure to get the waste wood out of the middle behind the shoulder of the vessel. The cutter will cut pulling toward the shoulder of the vessel when the cutter is swiveled to the left."
I hope that helps! It's always frustrating to get a new tool and have difficulties!
Good luck!
Dennis
Re: About 2 hours....
>Thanks Mike for both of your answers.
Could you clarify? did you mean two hours to turn it and then more time to sand and finish it or two hours total?
I was turning a piece of Osage and did not want to take the time to install the Jameson Captive system, so I tried the cutter free hand. Started with the attitude that it was crazy thing to do and the cutter was a little grabby. Was nervous about ruining a piece I was already two hours into and quit.
Got to make some sort of handle for that Hunter cutter. Hard to hold that little thing in your fingers.
I too enjoy the process. But sometimes my Engineering brain gets the best of me and I find myself thinking "If I sold this for X, I would be earning less than minimum wage." Then, "I will have to make forty of these just to pay for the Hunter cutter, let along the captive rig and lets not mention the lathe and those chucks." I should just quit thinking and enjoy the turning.
Mike Stafford
Mike Stafford
>Barry, I would guess that it is about 2 hours plus a little more for the average box. It is hard for me to estimate exactly how long it takes as I am waiting for finishes to cure between steps sometime. And while that is happening I am working on other boxes. Now if I could just get some more chucks....
And yeah, I know what you mean about hourly wages. I don't worry about that. I have no illusions about getting rich turning boxes. My goal is to pay for my tools, the wood I use and whatever else I buy for this most enjoyable hobby. Since I give away a lot of my work I can't fret over cost. But when I went to the NC Woodturning Symposium a couple of weeks ago that was paid entirely by monies I have made from my woodworking/turning efforts. As long as I am not borrowing from the family cookie jar I have no guilt about my expenditures.
