Chechen box...
Chechen box...
Mike Stafford
Chechen box...
Mike Stafford
>Mike Hunter sent me some prototype swan neck Hunter Tools to try on some of my boxes. Here is my first effort at an end grain box completely hollowed with the Hunter Tool. I had to go through a learning curve to find the correct angle of attack when using these tools and I also found it difficult initially to start a cut in the center and work from the center outward.
One of the reasons I was interested in the Hunter Tools was to reduce a problem I sometimes had with some of my boxes with undercut bodies. I was using a hook nosed scraper to hollow these undercut boxes and no matter how sharp the tool or how careful I was I would get some tearout on the underside of the upper shoulder that would require a lot of sanding. Mike decided to let me try his tools to see if they would reduce the tearout. Every box I have turned with the Hunter Tools have shown better results, less tearout and smoother initial finish before sanding. I also learned that I needed to increase my speed to have higher surface feet per minute. This increase in speed dramatically improved the finish of the bare wood with the Hunter Tools. Mike hopes to have some of these swan neck tools for sale in about 6 weeks.
This box is chechen which is very similar in my estimation to mesquite and is 2 1/2" in diameter and 2 3/4" tall. Comments appreciated....
Re: Chechen box...
Re: Chechen box...
>Beautiful boxes mike. I have some cocobolo I've been saving for some boxes. Your going to get me excited enough to dig it out and go for it.
I've been trying a new technique with the hunter tool on undercut such as below the lip on the lower half of this box. I keep the tool in the same orientation that I do when going from the bottom up. For me that's about 55 to 60 degrees tilted to the left. I keep it at this same angle but go from the lip down until I reach the previous cut. With the proper speed and technique this has worked on some really steep undercuts. It doesn't seem like it would cut backwards like this but it does. I find the #1 works better on the smaller boxes and the #3 on most of them.
I have to turn a bowl with a turned over lip for a friend so I'm going to try the same thing when turning the underside of the rim on this bowl.
Re: Chechen box...
Re: Chechen box...
Cyril Griesbach
>Mike and John, I ordered a Hunter tool for just this purpose (and others of course) and your discussions on it's use surely will be helpful when it comes. I'm sure to be in South Dakota when it arrives. John's introduction of the tool at Indyfest was the main cause of sparking my interest. My wife, Carol, has assigned this years Christmas gifts and they include an undercut rim with which I've always had tearout problems. But....now that we have started her on the turning addiction maybe she should make this years gifts.
Re: Chechen box...
Mike Stafford
Re: Chechen box...
Mike Stafford
>John, I think your description of what you are doing with the Hunter is exactly what I am doing as well. By tilting the cutter downward and rotating the shaft counterclockwise I am getting a nice sheer cut and as long as I have good tool control I am having very little tear out in the region you describe. I do find that I have to be cutting in the "right" direction.
Interesting that you are having success with the #1. I am not in the swan neck tools. I find that they have a tendency to bury themselves. I think they are so small that they want to have too much of their diameter cutting at once and that leads to vibration and once that starts you can expect a big catch. That is only true with the swan neck. I don't have the same control problems with the straight tools. Everything that I will be posting in the near future will have been hollowed with #3 straight or swan neck Hunter Tools.
Re: Chechen box...
Re: Chechen box...
Jim Shaver - Oakville, Ontario
>Big Mike!
I am enjoying seeing your work, always something I enjoy, and this "Hunter Tool" is that the secret weapons now?
Lovely form,
Take care,
Jim
Re: Chechen box...
Both are simple and elegant. Well done Mike!
gil jones
Re: Chechen box...
Re: Chechen box...
Carole Valentine
>John, I have been doing the same thing with mine on undercut rims. Works beautifully.
Re: Chechen box...
Mike Stafford
Not so much a secret anymore....
Mike Stafford
>Jim, I am continuing to learn how to use this tool. It requires a bit of control to use to its best advantage but when you have everything right this tool will remove shavings like a microtome. In all honesty it is amazing how well it cuts dense woods, the more dense the better. I have now had an opportunity to use Hunter Tools on hard curly maple, walnut, bocote, chechen, cocobolo, Amazon rosewood, curly koa, lacewood, kingwood, shedua, canarywood and cherry. I had success with all these woods. Lacewood, not being as dense did not cut to as fine a finish as the more dense woods but that is just the nature of lacewood.
I am still hogging out the interiors with my short bevel detail gouge but all the interior finishing is being done with the Hunter Tools. Of course boxes like the cocobolo with a squarish corner at the bottom are finished with a square scraper but the interior side, bottom and top surfaces are finished with the Hunter Tool.
They have become my "go to" tool. The tools seem to be cutting better now than when I started using them. I think there is a break in period where they are "too sharp" and perhaps a little more difficult to control. But once you are beyond that they become very predictable and work beautifully. Just like a heated ice cream scoop going through hard ice cream....
The short answer is yes, Jim. Thanks for your comments.
Re: Chechen box...
Dick Hines
Re: Chechen box...
Dick Hines
>You are killing me Mike.
Re: Chechen box...
Mike Stafford
Let me save you brother....
Mike Stafford
>Dick, go ahead and bite the bullet. You know you want to... Chuck up a piece of wood and turn a box. Try it, you'll like it! :>
Thanks Dick!
