Metal turning wood lathe.... 4 u Machinists....
dwr
>Metal heads... I need your help!!
I have finished six metal handles for my Doug Thompson tools and my hands and wrists have taken a beating... and I have another 6-8 handles to replace on other tools!!!
I know wood lathes used to serve double duty as metal lathes, so I want to add a cross-slide table and quick change tool post to my old Powercraft gap bed lathe so I can give my hands a rest and save them for woodturning. I have a 1.5hp motor and a VFD that works great, so I know I can dial in the right speed for the materials used (brass, aluminum and mild steel.)
My question:
How do I determine the correct combination of cross-slide and tool post/holders to fit the swing on my lathe, which is 12.875"? so I don't get the tool bits above the center height of the spindle. The cross slides I have been looking at are 4.5" total height and weigh in at 45# +/-.
Feel free to e-mail me off-line if you want.
Dave
Re: Metal turning wood lathe.... 4 u Machinists....
Dick Hines
Dick Hines
>I also use Doug's tools. I use the Kelton handle it was a lot easier on my hands. Just insert tool and run screws up tight.
>Are you making adaptors, ferrule or the whole handle. If you are turning the whole handle you really want power feed like a metal lathe will have. Even the long beds on the cross feed tables are too short for a long handle.
I guess to determine the height you would have to know what kind of fixture you will use to hold the tool. I purchased a tool holder that has adustable heights for my metal lathe. Enco had them for about $80 if I remember correctly. You would still have to build some sort of metal riser I think to get to the correct height.
Don in Central Illinois
>Dick, what size Thompson tools did you get and what size Kelton handle to you have? I have a Kelton #3 and I believe it would take a 1/2" Thompson, correct? I haven't purchsed Doug's tools yet until I know for sure they will work. Money's tight, don't want to waste it.
Dick Hines
Dick Hines
>I have a detail gouge that fits the small handle.
I also have 4 bowl gouges. Two 3/8 and 2 5/8. Thay fit the mid size handle. The 3/8 in one end and the 5/8 in the other.
Remember to either take the set screws out or wrap a piece on tape over them. It not you may spend some time looking in the chips for them.
dwr
>Dick,
I can make one 24" handle for about $12 including the steel shot and set screws. I have enough materials to make another 6-8 handles. It would have cost me over $500 to handle all 14 of these tools with commercial handles. I can justify a little money for a cross-slide, tool post, holders and cutters off eBay to help make my own. Plus I can use them in my woodturning as well... like for a threading jig, etc.
Thanks,
Dave
dwr
>John,
Pictured below are the six handles to date. The range from 6" for Christmas Ornaments and Boxes to 24" for large bowls. I started a pictorial thread a couple weeks back showing the process I take on one of the big tools.
I am turning two inserts that are pressed into each end of the handles. One insert is bored out to fit the Thompson tool and the other is bored and tapped for a plug making an access hole for the steel shot.
I am using either solid brass 360 alloy or aluminum. I have to turn down the insert that presses into the 1/4" wall aluminum tubing and that is what takes long time and really whacks my joints. I am using my Stronghold without any jaws and it works beautifully.
Once the inserts are made, I chuck the handle back onto the lathe and blend the inserts into the handle with a taper, cove, round-over, etc., for a seamless fit. I can do this by hand in a couple of minutes.
I will be doing facing cuts, parting off and turning to diameter. I am looking at a Rutland Cross-Slide with the following specs:
Working Surface: 5 1/2" x 12 1/4"
Cross Slide Travel: 4" x 8"
Table Thickness: 1.375"
T-Slot: 5/8" x 1 1/16" x 7/16" deep.
Dial Graduations: .001"
Overall Dimensions: 18" x 12" x 4 1/2" tall.
I was thinking of getting an import quick-change tool post kit that comes with half a dozen tool-holders. It uses the dove-tail attachments that look like I can adjust the tool holder height to the spindle centerline and then lock down the tool-holder. The tool post has a long bolt and nut that will lock down to the cross-slide t-slots.
I have 6.875" from the bed to the spindle centerline, so I don't think I will need a riser for the cross-slide (which is 4.5" high). If anything, I am afraid that the center-to-center of the tool-holder to the spindle might be too high... but I am not a machinist, so I need some input from those "in the know."
>I get ya now. I thought maybe you were turning the whole handle. That would take a fairly serious lathe.
Re: Hijack - which mats?
>And are they "comfy"?
dwr
>I got them at Woodcraft a few years ago when they had a big sale on a 6' stack of them... yes, they work great. They still run a sale from time to time.
Dave
Re: Thanks, they look comfortable..
>and just the thing to prevent a sharp tool from committing Hara-Kiri on a concrete floor (unless your shoes get in the way).
Dick Hines
Dick Hines
>I did not buy the handles just for using Dougs tools. I already had them along with the hollowing tools. I would have made my handles if I did not have these. Since the gouges fit the handles I could not see spending the time to make new handles.
You can't get there from here
Charles Sharp
>I don't think you are aware of what you are up against.
On a metal turning lathe you have a carriage that travels between the headstock and tailstock. It can be moved via the lead screw with power or you can move it with the handle on the front. The handle has gear on it that engages a rack type gear attached to the bed.
Mounted on top of the carriage is the cross slide, it moves in and out. It can also be moved by power from the lead screw or with a handle. The handle is attached to a threaded bar that engages the "nut" on the compound which sits on top of the cross slide.
The tool holder sits on top of the compound.
You could probably make something using threaded rod and slides to imitate the carriage and cross slide (you don't need the compound for your application) however you may be disappointed with the finish. It's hard to get a good finish moving the carriage by hand.
If you need someone to machine these things for you send me an email.
