Wolverine question - I'm feeling stupid
Pete
>I just got rid of my stock grinding wheels on my Woodcraft grinder and replaced them with Oneway wheels tonight. A little background: I got the Wolverine and set it all up a few years ago when I first got into woodworking, then had kids, and didn't turn for a while. Now I'm trying to get back into the swing of things again.
After installing the new wheels, I noticed that the arms are not properly centered under the grinder wheels. I feel silly saying this but I'm having a HECK of a lot of trouble centering them JUST right. Is there a trick to doing this or am I just being an idiot? I think I need to call it a night, hit the sack, and start fresh tomorrow evening when I get home from work!!
At least my wheels are properly balanced and spinning true now. I'm halfway there!!! ; )
Thanks!
Pete
Re: Wolverine question - I'm feeling stupid
Re: There should not have been ...
Jamie Donaldson
>.... any change with the wheel replacement??? Anyway, you should be able to eyeball the center of the wheel with the top center of the arm support channel on the mount for the tool rest. You may need fresh eyes tomorrow, but it shouldn't be a real problem?
Don't sweat it...
Peter Teubel
>IMO, as long as they are close, they'll do the job just fine. I just eyeballed it when I set mine up.
John Leonard
>Pete, if eyeballing isn't your cup of tea here is how I do it.
Find and mark the mid point of your wheels. Hold a pencil to each in turn on the mark and bump the on switch. This gives you a mark around the wheel. Next take a framing square (a small one will do) and place one leg on the midpoint line on the wheel and mark along the other leg on the bench. If the front of the bench (or wood you have the grinder mounted to is sraight, Place one leg along the front of the mounting board with the other leg on the mark. Now draw a line that is the center point of the base. It needs to be longer than the length of the base. Place the base on the board and align the front and rear of it with the line. Using screws mount it in place. Do the same for the other side. It's easier to do than it is to tell you how. John L.
Threepeatpete
>Jamie,
There were always a little off. My old wheels never ran true, and I just eyeballed the center line as best I could. Once I balanced these new wheels - it was painfully obvious how off I really was!
Pete
Re: Don't sweat it...
Threepeatpete
>Thanks Peter. It's been a long week already, and it's only Wednesday. I'll give it another shot tonight when I get home; I was just really tired last night and shouldn't have even bothered messing with things. But you know what it's like when that new package arrives!!! ; )
Threepeatpete
>Thanks John - I'll give it another shot tonight. I'm hoping I was just tired, and not completely imcompetent; I get up for work at 4:00am and I was running on fumes last night after a long day at work....
Pete
Pete, did you...
Clem Wixted, Jonesboro, AR
>...add any washers when you installed the new wheels? Are the new wheels wider than the original ones?
When you are not tired things look different. Good luck, let us know how you make out.
Clem
