boreing 1/8 diameter holes
richie
>Ive tried making 1/8" diameter holes in 8"long x1.5"diameter cylinders of ceder wood, for the purpose of making salt water fishing lures. the problem is that the bit dosent come out the center on the other side of the plug. Any ideas on how to keep the bit centered?
Re: boreing 1/8 diameter holes
E.T.
>Here is a secret from the old masters: Drill hole first then use the holes to center the wood between centers and THEN turn your wood to the final diameter. ET
Bill Crommett
>Richie: Try drilling the hole first and then configure the plug around the hole.
richie
>thank you all. that is the way to go .so simply , ill try to keep it that way.
Bill Hale / The Wood Spinner
>I agree wit the othere but just a point to remember about bits. Brad point bits don't wander as bad as regular bits.
Good turning and be safe
Bill in Casa Grande, AZ
>I shouldn't say never, but you will never be able to drill an 1/8" hole though wood and have it come out where you wanted. Except once in a long while you might get lucky. (NOT). So drill first, turn later.
Another thought would be to rip the blank down the middle, cut a groove in one or both pieces and glue it back together. You could use a router and a core box bit and cut round bottomed slots. This way you could make the hole even smaller than an eighth if you wish. If I were doing this, I would find something slick like string trimmer line that glue would not stick to to put in the grooves to index the two pieces and then pull it out, to keep the squeeze out from blocking the hole.
Re: thankyou all for the answers,their great
richie
Gary Evans Tallassee, TN
>Hey Richie,
I'm not understanding the importance of having a continuous hole through the lure. Is there a reason for that?
Gary
Gary
richie
>gary, the hole is to put a wire through so I can drill up from the bottom of the lure in the center and push the wire through the eye of a swivel to which a hook can be attached and also put a hook on the rear or the wire at the end or the lure.Im sure it can be done with eye hooks but these are salt water lures for stripped bass and blue fish. Ive examined store bought lures and thats how it seems to be made. I hope that explains my method.
Re: Gary
>Makes sense to me. I couldn't imagine that an eye hook would last very long unless you were using some very hard wood.
Gary
