>Ditto the above. I find it runs truer to center if you sharpen it better than they did at the factory. I use diamond hones. The jet will take 3/8". I prefer 3/8 over 5/16 because you can use short pieces of lamp rod glued into the holes to finish your lamp. Lamp rod is 3/8". If you want to put the lamp rod all the way through the lamp you will have to drill a 1/16 or so larger than 3/8".
You will need some sort of tailcenter to put the rod through. I bought the lamp auger center from Craft supplies and then put that in my Nova Live center. The lamp auger center has a short #2 morse taper so it fits right in the Nova center. Getting it out is another matter since the through holes are the same size. It has a set screw to hold the center point in. The center point is removed when you use the lamp auger. I drilled a hole through the side opposite the set screw. This does 2 things. It lets the shaving fly out without pulling the lamp auger all the way out, and I can put a heavy nail through the 2 holes and knock the auger center out of the Nova center using the Nova knock out bar. Is that clear as mud. If not I'll try to take some photos. I have my new camera now.
