THE WOODRAT IS BACK!
Coving Tools
Coving Tools
Coving Tools
Ben
>Hi all, I'm a new turner...I seem to be having a really hard time turning coves, mostly getting bost sides even.
Does anyone know of any sort of coving tools out there? Preferably in different sizes and at a reasonable price, I'm only turning as a hobby and I dont want to invest too much money it in.
I've found lots of different forums so I'll be posting the same message in all of them in hopes to find an answer.
Thank you all in advance,
Ben
Re: Coving Tools
Keith Tompkins
Re: Coving Tools
keith tompkins
>Ben, you need two things. 1. A spindle gouge 2. Practice
Here is the traditional way to cut a cove. Hope this helps.
Re: Coving Tools
Re: Coving Tools
>I think a spindle gouge is the correct tool. It does take practice to get it perfect.
I have also taught people to use a round nose scraper. You have to take very light cuts to keep from tearing the grain and start from the top down to the middle on one side and then do the same with the other side. Start smaller than the cove and then gradually enlarge it by taking wood from each side. You can't take a round nose tool and just push it straight in. It will tear up the wood chip out the top corners.
You use a spindle gouge the same way. With a spindle gouge you start with the flute pointed toward the middle. As you go toward the bottom you rotate the gouge so the flute is pointing up at the bottom of the cut. You must rub the bevel of the tool at all times during this cut.
Re: Coving Tools
Another trick
Troy German
>Mark the edges of the cove and mark the midpoint. Use your parting tool to set the depth at the midpoint. Remember to stay a little bit proud of your final depth to take into account the width of your parting tool. Then work from each side toward the center depth. A production turner can�t afford to spend time on extra steps but as a hobbyist why not, at least until you get more practice.
And remember, nobody will look at it as closely as you will.
Good luck,
Troy
Re: Coving Tools
Re: Another trick
>Another tip. If your trying to make sides that start perpendicular to the piece it can be tricky starting the cut without getting a little kick back that tears out the shoulders. In order to do this you need the bevel of the tool pointing exactly where you want the line to go. If you don't get it pretty close you can tear out the shoulder.
Make a very shallow cut with a parting tool or skew at this point. this creates a small shoulder for the spindle gouge bevel to rub so you won't get the little catch that tears out the shoulder.
Re: Coving Tools
Make a cove tool!
Ed Moore
>I buy 1/4" diameter high speed steel to make skews. However, if you grind a flat at about 30 degrees on the steel so that you see an ellipse and clean that up on some 800 sandpaper, then you have a cove tool. Use it with the flat side up much like you would a scraper (or drop-nosed scraper). Work it on each side, don't just push it straight in. Be careful not to rotate the tool so as to expose the upper edge and get a catch or skate.
Ed
Re: Coving Tools
Re: Coving Tools
Mike Schwing from Md.
>Ben, it is worth the practice time to get it right. The skills you learn will be valuable for many years to come, and you find application for them in many other areas.
Make a decision to spend the time to get it right. Find practice wood and do nothing but turn coves for a couple of hours. Wait a few days then do it again. Then again till you get it right. You'll be glad, I promise. All you need is a spindle gouge, but a skew, once mastered, is better.
Re: Coving Tools
Two cove tools
Ed Moore
>Here are two cove tools, one 1/4" and one 3/8". I checked the angle and they are ground at 25 degrees.
Ed
Re: Coving Tools
Re: Two cove tools
JohnKJordan in East TN
>You can also purchase these ready made. I bought one exactly like this from Woodcraft (Crown). However, I wasn't smart enough to learn how to cut cleanly with it so I reground it into a three-facet point tool.
Re: Coving Tools
Re: Coving Tools
Neal Addy
>Folks, this is a hoax. "Ben" has already been caught on another forum.
Not long after posting his question he answers himself under a different name (but again as a first time poster). This has been verified from his IP.
The second poster provides a link to a tool site. He's done this on at least two other forums. Guess he didn't have time to get the second post in here before his scheme was uncovered.
Tactics like this are NOT a good way to start a business, Jonathan (or whatever your real name is).
Re: Coving Tools
HOAX!!!
Ron in Drums PA
>This person will follow up with an answer using a different name to sell his tools.
He has been caught making the rounds on other forums.
Re: Coving Tools
Tool marketing hoax
>If so, it's a shame to feel the need to lie to make a buck. On the gripping hand, it spawned some good discussion about cutting coves.
How about posting the link to Jonathan's tool site so as to affect a boycott? Some in this community may not even want to accidentally purchase from this source.
Re: Coving Tools
Re: HOAX!!!
Neal Addy
>John raises an interesting question. Do we post the URL to this guy's website so as to affect a boycott? Or would that be ethical?
I'm hesitant to just throw it out there and further his cause.
Re: Coving Tools
Re: HOAX!!!
Ron in Drums PA
>I think a better idea would be to show people how to make the tools. They are easy to make.
Ed's tools are exactly like this spammer's tools.
Re: Coving Tools
Re: Two cove tools
>Isn't that just a spindle gouge without the groove down the outside?
Re: Coving Tools
Re: Two cove tools
Ron in Drums PA
>I have a tool almost like this. (I'll take a picture tonight)
It started out as a 1/4" round HSS bar. I ground a long flat surface on top, then ground the sides like a gouge. Excellent for coves, tiny beads and cleaning the bottom of any form.
Last year at TTS in Albany, both Kieth and Cindy Droza (sp) had one that they where using. I copied stole was inspired by their idea.
Great Tool and easy to make too.
Re: Coving Tools
Shameful.
Dave Winters
>I can't begin to describe how this makes me feel. I think I need a shower.
Re: Coving Tools
Re: Coving Tools
Jonathan Hess
>This is a copy of an e-mail I sent to the AAW forum moderators. I had nothing to do with this attempt to sell anything. I regret my friend took this action in my name. Rest he will hear from me.
To AAW
Gentleman: I'm a member of AAW. I'm sending this to both of you in the
hopes you can act quickly. Do not allow any postings from someone named
Ben or nvaturner. I think I have the names right.
I seems a well intentioned but utterly misguided friend of mine has
tried to "help" me by posting a question about coving tools and then
loggin as some one else and giving my web URL.to my web site where I
sell coving tools of my own design. He did this on at least four other
forums. He is not a woodturner nor an IT professional. As a woodturner
and former IT
manager, I would never approve or condone such behaver. Of course the
other moderators caught this right away and now have labeled me a hoax,
trying to gain free advertising on there forums. Perhaps you could post
this in the forum in the hopes that my fellow woodturners would
understand what has happened and maybe restore their faith in me and my
tools.
I am sure my friend ment no harm, but he has done me a great disservice
and may have ruined my chances for any success. Since my site is only a
few weeks old, I have not really gone public and have done no marketing
or promotion as yet. I may not be able to now.
Rest assured, when I get him on the phone, I will give him a lashing not
heard since my days as a member of the 82nd ABN. DIV.
Please accept my apology to all AAW members and to the woodturning
community in general for any trouble this may have caused.
Thank you in advance for your attention to this matter.
If you need to contact me for more details or any reason, my # is
703-378-8508.
p.s. Since my name is mud at these other forums, do you have any
suggestions as to how I can get in touch with these moderators??
Jonathan Hess
jonathanh@bestmail.us
http://www.fastmail.fm - Access your email from home and the web
Sent Items: 1 of 1 �� Prev Mailbox Next �� Switch to Advanced screen
Tip: Your monthly bandwidth usage is limited, based on your service level (more information)
Need help? Start here. Read the FAQ. Talk to other users. Copyright
Re: Coving Tools
Re: Coving Tools
Mike Schwing from Maryland
>I still think you should take the time to learn coves the old fashioned way.
Re: Coving Tools
Making cove tools
Ed Moore
>With this "originality" discussion that has just crawled out of the woodwork again, let me say
I HAVE ABSOLUTELY NO IDEA WHERE THE IDEA FOR COVE TOOLS CAME FROM. THEY WERE NOT MY IDEA, AND I DON"T KNOW THE ORIGINATOR, BUT I'M NOT SELLING THEM.
Ed ;^D
