Some More Robust Pictures
Bill Grumbine (Kutztown PA)
>Greetings all
I meant to get this posted some days ago, and actually did in a couple of other places, but then real life got in the way of me and my computer. The lathe arrived about 3:00 PM last Wednesday, and all went very smoothly indeed. The truck driver was a very friendly guy who was willing to help us get the thing into the shop. Getting it off the lift gate was a little exciting, since it barely fit, especially with three guys (one of them me!) also trying to stand on the lift gate to move it around. Including the crate, it checked in at 920 lbs.
Once we got it on the ground, we removed the excess crating - i.e. everything but the skid, and prepared to get it into the shop. My shop is at ground level, but not quite. There is a lip of concrete about 1 1/2" high which we had to surmount. We got the thing onto the pallet jack, took a running start, and got it most of the way in on the first try. It took two more tries to get in all the way, but it went relatively fast.
After signing papers and sending the driver on his way, I had this in the shop.
It was very well wrapped in what looked like a giant garbage bag and that foam stuff that electronics come in. It only took a couple of minutes to get all that off, and then the real grunt work began. After getting the bolts holding it to the skid out of the feet, we prepared for the heavy lifting. The headstock, banjo, and tailstock were all moved to one end of the lathe, and boards were placed at the other end so that we could slide it along the skid. We dragged the "light" end off the skid and set it on the floor. Then, we moved all the stuff on top back to that end, and prepared to get the second end on the floor. We did that by padding a long crowbar with some of the foam, sliding it under the ways, and lifting from two sides while my daughter removed the boards. Now it was sitting firmly on the floor with the skid wrapped around it. No problem, that is what reciprocating saws are for! In very little time there was a pile of scrap two bys laying out in the parking space, and we were at work getting the lathe up on its wheels.
The wheel kit is an option, and comes with a jack, which also serves to lift the lathe to adjust the leg height. Most people will probably use something like this once or twice, but I think it is going to be real handy when students of less than normal height (6' 2") come to use it. It will also be a plus if I want to do demos, or need to make full use of the bed (more on that in a minute). I got it as far as you see in the picture above last night before it was time for bed. I had to run some errands as well, so I was not able to devote my undivided attention to the machine.
Here is a shot with the tailstock pivoted. This is a huge advantage for me in a couple of ways. While most people will like it because it gets the tailstock out of the way for turning at the end of the lathe or using a captured hollowing rig, I have the added advantage of it enhancing my flatwork capabilities. With the lower bed ways and the tailstock out of the way, the slider on my Mini Max combo machine will sail right past it, with sheet goods passing over the ways. That adds a minimum of 30" of space to the other end of the shop, all the way across, effectively opening up about 30-45 square feet or better. And because of the wheel kit, the lathe does not need to be out in the middle of the floor all the time. I don't need the 58" between centers all the time, and since the headstock slides, I can condense it down to a smaller profile for most of my turning, and if I need to stretch it out for a longer piece, it will be a simple matter to put the wheels on, and move it out to where I can use its full length.
I got the lathe leveled the next day with the help of a friend. What a job that turned out to be! The lathe was not the issue, but rather my shop floor. The floor is concrete, poured in 1943, with no intention of anything but parking and working on cars. As such, it has more billows than the North Atlantic, and as much oil on it as when Exxon Valdez became a part of our history. I have an unpleasant combination of rough and slippery. We tried the leveling feet that came with the lathe, but they were too small and moved around. So we went back to moving the legs, which are infinitely adjustable. We got it dead on level in all directions, but it kept skating around like a pat of butter in a hot frying pan.
I didn't have this problem with the Poolewood, but my friend (who happens to own the Poolewood now) pointed out that the feet on the Poolewood are hollow tubing, whereas the feet on the Robust have a plate welded onto the end, and is painted to boot, creating a lot less friction. So, we bolted it down to the floor using some Tapcon screws.
I fired it up again, and it was still vibrating. Checking the speed, I realized it was running at about 1200 rpm with a 16" out of balance blank. I backed it down to about 900 rpm and we could stand a nickel on edge with no problem.
Here is a picture of the first shavings. I took a piece of silver maple that was still somewhat wet, about 16" in diameter to start, and perhaps 5" thick or so. I leaned into it with all I had using a Thompson 5/8" gouge, and taking off as big a shaving as the gouge would handle. I was able to slow the lathe down somewhat (haven't met one yet that I can't stall) but you can see the shavings in the window there. Taking the heaviest cut the gouge could swallow, the nickel still stood on edge. So I am happy.
The rest of the shop now needs some serious work, including some new tool storage, and I have to finish my dust collection, but I am planning to have some pieces to show as soon as possible.
Thanks for taking a look.
Bill
Re: Some More Robust Pictures
Brian Hahn in SW Wisconsin
>Congratulations Bill!
Those casters are really handy. Brent used them to roll the lathe into my shop. My shop floor is flatter than yours but not quite as rigid, so I have a different type of flooring issue.
Did I read your post correctly? You were able to slow the lathe down but not stop it?
Enjoy!
Steven Antonucci
There will be a big line at Five Barns '08!
steve antonucci
>You should plan on limiting turners to 20 minutes of Robust time to avoid fights breaking out-
Congrats on the big iron
Steve
Norm Smith
>Bill, Congratulations. That is a beautiful looking machine. I look forward to hearing more about it and, if you can take the time to tell us how it compares with others in its class.
Norm
A Real Wisconsin Beauty
Cyril Griesbach
keith zimmerman, Normal, IL
>I sure hope I can schedule 5 Barns in 2008 so I can see and turn something on this new lathe, Bill.
Congratulations. Can't wait to see something turned on it along with observations about it's operation.
keithz
Jennifer@Indy.USA
>Looking good Bill! Aren't you feeling just twinge of sorrow for Big Blue though?
Enjoy the new toy!
Jen
Steve Kubien
Steve Kubien
>You could turn some big-a**ed pens on that thing! Looking forward to meeting up with you in a few weeks at the christening.
Steve Kubien
Doug Thompson near Cleveland
>When is the christening? I might have to be there.
Nice one Bill!
Steve Kubien
Nov 3rd
Steve Kubien
>Love to see you there so I can personally thank you for the wonderful gouges (and maybe get you to bring a couple of new ones with you:)).
Steve Kubien
>Like this one Steve?
I made this as a gag gift for an old friend who was old. I think it was his 84th or 85th birthday, and I will tell you the rest of the story when I see you.
Bill
>Brian, I did slow it down. I think I could have stopped it, but I did not want to break anything the first day, including any body parts on myself. I have yet to meet the lathe where I have not stalled it inadvertently or even "advertently". ;-) I have not tried this one out on the lowest belt setting yet, although I have had it at the top end already for some spindle turning.
Bill
>Jennifer, I sort of miss Big Blue, but I am feeling a lot better about it now that the Robust is here. I really like my Vega, but long sticks ain't in it! And my Vicmarc is pre-bed extension, so I had to drive 15 miles to Woodcraft to make some tool handles.
Bill
I'll be there
>It's a 400 miles from here so I'll drive up friday. I have a 3/4 V shape bowl gouge that might be perfect for this lathe. Heck I might bring my personal tools and turn Bill a hat... wait trees don't grow that big (just kidding) I'll bring them anyways because they are still packed up from the Indyfest.
See you in two weeks.
Lookin' good Bill!
Dominic Greco in Richboro PA
>Bill,
Man oh man does that look sweet! Oh yeah, the Robust looks good too. I was referring to the top notch dust collection piping that is installed in your shop. :>)
When are you going to pipe the down spout for the dust collection at the robust? It's just going to be a section of 5" flex, right?
I can't wait till the 3rd to see that bad boy (I mean the lathe this time) in person.
See ya around,
Dominic
Looks real good, Bill
Ted Owen, Pittsburgh
>Hope it gives you years of service.
Best, Ted
Steve Russell
>Hello Bill,
Congrats on the new lathe! :-) There's nothing like unwrapping a new lathe... Glad to hear your lathe was delivered safely. I have the unwanted distinction of being the first person in the U.S. or Canada (according to Oneway) of having a Oneway 2436 dropped by a delivery driver. It fell five feet to the ground, off the end of the lift gate as I watched the whole sad scene. It sounded like a bomb going off when it hit the ground and neighbors from several surrounding homes all came out to see what happened.
The delivery driver then calmly asked " Do you still want it?" I looked at the crate, (in pieces) and said "No"... Six month's of waiting down the drain. Luckily, Oneway helped to to get a replacement in about a month, but it still smarts when I think of it.
I sold my first lathe (the big green beast) several years ago. It was a Woodfast 910V, a real sweet lathe. When my studio's direction changed into larger pieces, the old Woodfast had to go. I still miss turning on a Woodfast... It's sorta like your first car, you always remember your first lathe and miss it as time goes by - if you had to sell it.
Glad to hear everything went well for you and please accept my very best wishes to you, as you start making new memories with your new Robust. Take care and all the best to you and yours!
P.S. I may be up in your neck of the woods sometime next year on business. If that plan gets traction, I would love to stop by and meet you. I'll be happy to bring some Mesquite blanks (or any other Texas wood) and a few other assorted goodies as a belated "Welcome" gift for your new lathe. Cheers!
Steve Russell
EWW, WVP, EWWFS
The Woodlands, Texas
Re: I'll be there
>Doug, if you were going to turn a barrel for me to wear, that could be a problem, but a hat? I've got some big silver maple here...probably make a couple of hats.
Looking forward to seeing you.
Bill
Re: Lookin' good Bill!
>Well I haven't gotten it done yet Dominic, but I am going to "hinge" the drop with some flex, add in a tube of rigid metal duct, and then finish it off with an elbow or something. That way I can lift it up out of the way when I don't need it.
Bill
>Steve, I would be glad to meet you, and even trade some PA hardwood for some of that Texican stuff. I don't know if we can fit all those letters into the shop though. You might have to come in warm weather when the doors are open! If you don't mind my asking, what does all that stand for?
Bill
Steve Russell
>Hello Bill,
Since I hunt and peck on a keyboard, that's my lazy way to note my three companies:
Eurowood Werks Studio, Woodturning Videos Plus and Eurowood Werks Film Studios
My wife types about 140 words per minute, but when you type with your elbows like me(nearly anyway), you take every shortcut you can get... As for fitting into your shop, no problem with the initials, but I'm not getting any smaller as I get older. What's that you say about a "Turning Muscle?" ;-) Mine seems to be growing these days... :-o
No matter, I will be happy to put together a Texican "Goodie" box for you. We have some really nice Guyacan down Mexico way that is a joy to turn. It does not get very big, but it's a magnificent timer to work with... Our Mesquite is legendary and is one of the most stable timbers on the planet. Texas Pecan-crete is hard as concrete, but really nice to work as well. Not to mention all of the Sycamores, Elms, White Ash and others. We don't get many burrs down this way, but even a blind squirrel finds a nut every once and a while. :-)
Take care and make a few shavings for me on that new bad boy... Makes me want to buy another lathe. :-) Best wishes to you and yours!
Steve Russell
EWW, WVP, EWWFS
