?? for you woodburners
Danny Wells
>I think the Eagle or Hawk models of the Burnmaster woodburner have been recommended on here before. I'm getting ready to purchase one of these. Your suggestions would be greatly appreciated.
1) Is the Eagle with the two handpiece ports that much of an advantage?
2) Which handpiece do you recommend..the Burnmaster solid state system or the Burnmaster replaceable tip system? Or another brand?
3) Which tip shapes would you recommend to someone for the basics getting started?
Thanks much,
Danny
Re: ?? for you woodburners
Andi Wolfe
>Danny - the one port vs two port option depends on whether you often use more than one tip on a project, and how often you need to switch between the two. I use a one port system because I don't have to switch pens very often. Molly Winton prefers the two port system because she does switch back and forth a lot. You still have to switch between the ports, so I don't find a big savings other than not having to plug the cords in and out.
For pens, I recommend the permanently wired tips because with the pressure and temps I run, I get a better connection and more consistent heat control. Detail Master pens 6A, 10A, and 7B are my usual ones, but I also add some specialty pens from Razor tip for some types of texturing options.
All that being said, your options depend on what style of pyrography you want to use in your work. I use high temp and a lot of pressure to achieve the textures I'm after in my work and so I need a unit that handles a lot of current and pens that are very sturdy and hold up to high temps and applied pressure. If you're after more of a traditional "pen and ink" effect with the pyrography, you can use other systems and pens with good results.
Hope this helps a bit - Andi
Jake Niedling
>I have the Detail Master with one port. It works fine for the little bit of burning I do. Besides the Detail Master tips, you can buy the Razor cord and plug which fits into the Detail Master, so you can everything they offer as well.
russb
>I have the DetailMaster Sabre IV, very nice unit. I use the DetaiMaster fixed tips on recommendation they make better contact between the tip and handpiece for better heat transfer. I make my own adapters with parts from Radio Shack for using pens from different companies. Today I would look at the Burnmaster units. They offer the same specs at a lower price and I have read good things about them.
Danny Wells
>Thanks Andi,
I really appreciate your help. I'll probably go with the single port and your recommendations for the starter pens makes good sense. I want to do some embellishment on my turkey calls and duck calls primarily, maybe on some of my other work as well.
I visit your blog once in a while. Being a forester, I think it's cool that you get inspiration for your woodturning and art from your profession, so I check the blog every so often to see what's going on.
Thanks again, and thanks to Jake and Russ also,
Danny
