woodburning kits
woodburning kits
woodburning kits
mark4583
>Anyone do any woodburning? Id like to try some on Pens, Bowls and Vessels,
Any suggestions or oppinions on what kit I should look at?
Thanks
Re: woodburning kits
Mike Jones
>I have the "Razortip" unit. I bought it after a professional demo at Woodcraft...also available with other cool woodcraft stuff at Treeline.
http://www.treelineusa.com/cgi-bin/shopper?search=action&keywords=razertip-burner
Karen F
>Mike, I have both the Razorzip and a Detail Master and I pick the Detail Master every time. It holds the heat at much more steady rate. That can be a big problem when you're burning something like quilted maple or any wood with both hard and softer wood. Razorzip tends to loose the line you're burning when it hits a hard area.
Andi Wolfe said she has used a Master Burner and likes it too. So that's another option. Razorzip is fine for some softer woods but the handles can get very hot in your hand.
Mike Jones
>Should have talked to you first! The Razortip does get hot, and requires me to stop...change pens, or take a break.
Re: woodburning kits *LINK*
>Mark I've been real happy with the Optima. The pens run a lot cooler than my old burner. They still eventually get hot but it takes a long time. Most important for my style of burning is the control of the heat. I tend to use the scortch or lightly brown method for a lot of stuff and this tool maintains the correct temperature very well. I also notice the difference when I'm burning lines across the summer winter wood that vary in hardness. This tool is a lot easier than the last one I had.
http://www.carvertools.com/aboutpjl.htm
