Unscientific survey re: lathe chucks
Joe Pack
>Okay, I'm learning. Bear with me, but, in this case, I have a suspicion that you have been there too....
The survey question is this: How many times did YOU rap your knuckles or lose some skin or chunk out a fingernail before YOU learned to stay out of the way of a spinning chuck? If your answer is 37 or less, you are a lot quicker at learning lessons than me! In fact, if your answer is anywhere under 96, you probably beat me!
So, if you can remember, and either want to brag or commiserate, how many times did it take YOU to learn your lesson?
Re: Unscientific survey re: lathe chucks
Bill Howatt
>I must be brilliant! :)
I have (surprisingly) only hit it about 3 times and no damage was done, just woke me up a bit. I usually try to keep the jaws more closed than open when gripping a tenon so the outer surface of the chuck is smoother.
You can buy a chuck-cuff which is a brightly colored piece of elastic cloth that you slip over the chuck. Easier to see and if there are bumps on the chuck from the jaws it smooths them out. Lee Valley and other sell them or you can make one yourself.
Bill
Chuck cuff
Joe Pack
>I actually have a chuck cuff from Lee Valley. When I put it on and fire up the Jet mini, it just balloons out and flies off. Maybe I have the speed too high. Right now I am just turning thin spindle-like objects, and the extra speed makes the friction polish "pop" well. Maybe I need to slow down when using the chuck.
Allen Neighbors
>I've been turning since '03, and I still get a little rambunctious sometimes and get a rap. So evidently I haven't learned the lesson yet. :) Besides, I'm a klutz. Happy, but a klutz.
Mark Wollschlager
>This was not an original thought, can't remember who described it first.
If I am turning with the chuck jaws open past the body of the chuck, I wrap a piece of painters tape around the chuck and leave a tab of tape 3/4" - 1" sticking out.
It serves as a warning when I get too close when I get wapped by the tape.
It also gives me a visual clue like the chuck sock would.
Mark.
Re: Chuck cuff
Allen Neighbors
>Joe, you can get a thing called a Dek-Tite at most lumber yards, and you couldn't spin it off regardless the speed. It's the thing they put over through-the-roof vent pipes to keep them from leaking. I got one the right size, cut out the center and slipped it over the chuck, when my first chuck was an old 3-jaw chuck whose jaws protruded past the body. It would expand with the jaws. I don't use it on my Nova's.
Carole Valentine
>Only one that has gotten me is the Cole Jaws and that only happened once when I first got them. Didn't do any damage but served as a wake-up call.
Wally Dickerman in Arizona
>You youngsters don't remember the days before the 4-jaw scroll chuck when we used 3-jaw machinist's chucks. Now there's a REAL knucklebuster. When those 3 jaws are sticking out beyond the chuck body they're lethal....what is really lethal is when my 3-jaw fell off the workbence onto my big toe...The doc said my toe wasn't just broken, it was crushed.
I still use the 3-jaw once in a while. It can be a very handy tool for certain things.
Wally
Me too...
Scott Hurley in N. VA
>Apparently I haven't learned my lesson yet, either. No damage except for a couple of bruised fingers so far...
Scott
Steven Antonucci
Honestly, never happened?
steve antonucci
>Nowm I have used the chuck way more than 1000 times to slow down the lathe instead of the handwheel, and once or twice forgot that the jaws were past the body. I can tell you from experience that you know immediately how bad of an idea this is when the jaws catch your palm and attempt to snap every bone in your wrist.
I don't do this any more...
Steven
Dick Hines
Dick Hines
>I have been turning for 10 years or so and still get a finger to close once in a while. Check the post "If you are stupid you are suppose to suffer" from this pst week.
Gotta write that one down!
Joe Pack
I think I've been lucky
keith zimmerman, Normal IL
>Closest I have ever been to experiencing any hurt from my chuck is that feeling of the jaws skittering across my skin...just enough to tell me to pull away.
keithz
Barbara Gill, Remlik VA
>I have had lightly rapped knuckles several times but no damage.
I used them, too, Wally. 3 jaws but
Ruth Niles
>a lot more lethal than 4 jaws. Those self-centering machinists chucks are terrific but they don't just hit the knuckle and take some skin, they want the whole finger! Actually, if you are as aware of the jaws as you are the saw blades, you'll do just fine.
Carole Valentine
>Owwie!That makes my toe hurt just thinking about it, Wally. Another good reason for steel toed shoes in the shop I guess, but I do LOVE my sandals in hot weather. :( I have had a couple of close calls with dropped or knocked-off-the-bench tools, which always seem to land cutting edge first.
Re: I think I've been lucky
>Same here but I've attempted to stop the chuck with a gouge every now and then. I tend to work too close to the chuck and if the wood gives way or a get in a hurry I take a nice nick out of both chuck and tool. I hate it when I do that. Of course with the Thompson tools I get about 2 nicks before I have to sharpen. :)
Not Yet
Ron in Drums PA
>But watch what happens the next time I use a chuck
I'm not superstitious :(
>I have several Nova chucks. I have been "blooded" several times but no serious damage. (I usually have a nick or scratch somewhere. Is that just me?)
You can make a chuck cuff out of a small inner tube, like the one for a wheel barrow or trailer tire. Check with a tire place and they may give you a used one.
What really SCARES me is those holes in the Nova chucks. The ones for those big goofy chuck keys. Can you imagine managing to stick your finger in one of the while the chuck was spinning? That's a really good reason not to buy this type of chuck. Get the newer ones with the Allen keys.
Chuck Engstrom
>I took a bad hit from a chuck once under some sort of lighting that made the chuck appear to have slowed more than it had. Since then I have always tried to have at least one old-fashioned incandescent bulb on the work to minimize the strobe effects of some of the more modern light types.
Whenever I get a new set of jaws they go first to the grinder, where I soften any edges that may protrude in use. I still get bumped a bit but not sliced and diced. I also remove the jaws slides completely and soften the outer ends of them. Performance doesn't seem to be affected at all.
Best--
Chuck
eaglesc
>None, I only make pens.:>)
Re: I can't say that I've ever been "had"...
>by a lathe chuck. But I do mostly spindle work - and I have a nice hand knitted chuck cuff. About the only time I really use my chuck is when I put a tenon the ends of my rived spindles (3/8" and 1/2") and if I screw up and cut off the ends before I've completed a turned piece.
Re: Chuck cuff
adrien
>Thanks Allen. I'd tried a piece of inner tube. Result was same as Joe's. gotta try Dek-Tite.
JohnKJordan in East TN
>Respect for (read 'fear of') the chuck is one reason I often use the morse taper of the headstock as a jam chuck when turning long, thin spindles. Works as well as a scroll chuck, provides more clearance, and has no knuckle-busting potential.
As for the experience, once was enough for me.
Maybe once...
Brian Hahn in SW Wisconsin
>I bought my first scroll chuck back in '96 and I might have gotten skinned by it once or twice, but I really don't remember. I sometimes lightly rest my hand on the body when I'm doing spindle work and need to cut right next to the jaw faces, but I've never gotten bitten doing that.
